10-16-2015, 21:39 | #1 (permalink) |
Junior Member Join Date: Feb 2007
Member: 453077 Status: Offline Thanks Meter: 1 | Iphone 6 Plus front camera and earpice stoped working Its not the front camera flex, i replaced it multiple times for new ones, i even repleced complete display with all the flex from a working 6 plus and no luck... And mainboard becomes very hot after some minutes... Conector seems ok... PLEASE HELP Last edited by Vibore; 10-16-2015 at 21:44. |
10-17-2015, 10:00 | #2 (permalink) |
No Life Poster Join Date: Mar 2012 Location: Amsterdam, Netherlands
Member: 1732818 Status: Offline Thanks Meter: 532 | image search Change the front flex cable first! Specially when the phone gets hot at the top. If that didnt solve your problem, Then Check the RED marked points for your missing ear audio. Check the YELLOW marked points for the front camera. There are more points to check, but these points are easy to damage. Jumper the filters or replace them if missing. |
07-15-2016, 09:37 | #5 (permalink) |
Junior Member Join Date: Jul 2016
Member: 2598645 Status: Offline Thanks Meter: 1 | hi Everyone I just changed broken lcd to oem Apple lcd. Then earpiece and front camera didn't work, so I changed flex cable. Earpiece now works but the front camera still don't work. so do you guys think checking yellow circles from hdccam reply and fl111x components from smangsm reply? I have a cheap $5 multimeter. how do I use this to check. I only know how use ohms meter function. pls help me step by step with multimeter. I took high school electronics and can repair components like fuses, resisters, capacitors, jumpers and broken traces with ohm meter. thank you all |
The Following User Says Thank You to Nipsta For This Useful Post: |
07-15-2016, 11:29 | #6 (permalink) |
Member: 2598645 Status: Offline Thanks Meter: 1 | Okay guys, so I googled fl1111, fl1112, etc. it says it's resisters at 120ohm. Is this correct? If I find a bad resister, where do I find the replacement? Please advise. Thanks in advance. |
