11-22-2017, 16:43 | #1 (permalink) |
Junior Member Join Date: Sep 2012
Member: 1807779 Status: Offline Thanks Meter: 0 | Iphone 6 Plus no sound there was no sound at all replaced the u0900 ic now there is sound and mic and loudspkrs working in camera but in calls there is no sound at all when there is incomming call there is a ring that there is call incoming does anyone incountered this kind of issue and is there a solution for that? |
11-23-2017, 03:20 | #2 (permalink) |
Freak Poster Join Date: Nov 2017 Location: Canada
Member: 2777379 Status: Offline Thanks Meter: 34 | did you tried a different housing and different LCD screen? this could easily be an issue on the screen itself, if not then audio IC could be bad reball it again |
11-23-2017, 09:26 | #3 (permalink) |
Member: 1807779 Status: Offline Thanks Meter: 0 | well i've tried with diffrent lcd and the front cam flex and another charger flex there is sounds but not durning calls and replaced that ic once again and checked the pads they seems fine |
11-25-2017, 18:52 | #4 (permalink) |
Member: 2777379 Status: Offline Thanks Meter: 34 | Look where the display connectors are to check for any damage on the one that connects the front speaker to, if nothing then try to restore the ios completely could be a software issue also, had alot of phones with only no front speaker issue and it was software issue. |
