04-28-2016, 14:22 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: iraq
Member: 1212320 Status: Offline Thanks Meter: 46 | iphone 6 plus short only on power supply this is iphone 6 plus short and heat on Q1403 only on power supply i used tho solve this problem on iphone 6 by removing C1552 put its not working with iphone 6 plus i removed some capacitors that on PP_VCC_MAIN but still short |
07-27-2016, 18:08 | #4 (permalink) |
Insane Poster Join Date: Jul 2016 Location: oman Age: 34
Member: 2603722 Status: Offline Sonork: GSM BANGLADESH Thanks Meter: 7 | Iphone 6 / 6 Plus: Iphone 6 / 6 Plus: How to Fix Black Screen, Display Wont Turn On, Screen is Blank I give you three easy possible solutions to get your Iphone 6 / 6 Plus display working again. Option 1: Hold down home and power button simultaneously until you see the Apple logo. Option 2: Hold down power button for 3 seconds then hold down the home button until Apple logo appears. Option 3: Firmly press directly under your flashlight and camera lens as your back light display connector may have gotten dislodged. |
07-27-2016, 18:51 | #5 (permalink) | |
Freak Poster Join Date: May 2012
Member: 1760128 Status: Offline Thanks Meter: 56 | Quote:
Are you kidding me???? Lol! Sent from my iPhone using Tapatalk | |
07-28-2016, 17:58 | #6 (permalink) |
Junior Member Join Date: Jul 2016
Member: 2604344 Status: Offline Thanks Meter: 1 | I had that on one iPhone 6, short detected on Q1403, when U take it off there is no short? My was under the PM8019. Need to take off Q1403 check if it stiil short, if not change or rebball PM8019. |
07-29-2016, 18:14 | #8 (permalink) |
Member: 1760128 Status: Offline Thanks Meter: 56 | We are talking about 6 plus and it's not the same! More of that it can be anything in pp_vcc_main connect it to power supply and follow the heat not alway guide you correctly. Try to look after capacitor that look bad or black in vcc_main line! Not all what is hot means it's bad or short! Sent from my iPhone using Tapatalk |
07-29-2016, 18:23 | #9 (permalink) |
Member: 2604639 Status: Offline Thanks Meter: 3 | capacitors in 5% cases looked bad. to tomerzhr look my blog http://www.fix-surgut.ru/дайте-позвонить/ this capacitor looked perfectly however is short. |
07-29-2016, 18:38 | #10 (permalink) |
Member: 1760128 Status: Offline Thanks Meter: 56 | iphone 6 plus short only on power supply 5% I will say more then 50% And Samsung is not the same like iPhone. They build different, Samsun Is piece of sheet compared to iPhone. Sent from my iPhone using Tapatalk |
