Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 10-25-2018, 11:51   #1 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 71
iphone 6 plus touch screen problem in detail
iphone 6 plus a little bend,touch screen sometimes work herself.
operations: rehot mesons and cumulus, touch work but lower touch screen zone bad tracing and not sensible,whit oem lcd assembly is same result.
reball black ic meson:touch work only after some minutes after power on phone and all touch screen lines works ok,phone off and wait some time,reboot and no touch again,whit oem lcd assemby same result.
reball black ic again and make jumper on m1 pin:touch not work at all,never,display images are ok but some very a little visible vertical stripes,
whit new oem display set nothing visible,all black!!!
removed crystal cumulus ic and meson...and i lost 2 pin under meson
pads say one is gnd and one is in net whit some other pin,but another pads scheme say me different,one not connected and one gnd.
i need help for solve pin and touch screen problem,thanks.
pins lost are in photo attached.
thanks.
The Following User Says Thank You to nykocam For This Useful Post:
Old 10-25-2018, 16:50   #2 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 71
after change 2 touch screen ic brand new u2402-u2401,touch screen still not work.
Old 10-26-2018, 07:21   #3 (permalink)
bobo bokota's Avatar
Member: 2148606
Sonork: Bobobokota
Thanks Meter: 494
You jumper m1 to U2402
Envoyé de mon itel P12 en utilisant Tapatalk
Old 10-26-2018, 08:27   #4 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 71
yes jumpered m1 as can see in the 2nd photo,no success,touch screen don't work.
Old 10-26-2018, 11:07   #5 (permalink)
Member: 658949
Thanks Meter: 13
Do you have those voltages: 5.1v at C2402, 1.8v at C2415, 1.8v C2403 and 1.5v at 2432 and 2433?
Enviado do meu iPhone usando Tapatalk Pro
The Following 2 Users Say Thank You to gscardua For This Useful Post:
Old 10-26-2018, 11:08   #6 (permalink)
Member: 658949
Thanks Meter: 13
And you can change U2403 too
Old 10-26-2018, 11:10   #7 (permalink)
Member: 658949
Thanks Meter: 13
Check if R2436, R2435 and R2434 are in right place and if they aren't open
Old 10-27-2018, 08:49   #8 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 71
thanks,i will try soon
Old 10-27-2018, 21:00   #9 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
This is not about broken M1 pad. When M1 pad is broke you see only grey bar on top.
This photo looks like you don't reach the proper temp to stick the chip on board.
Old 10-28-2018, 12:50   #10 (permalink)
Member: 242825
Thanks Meter: 10
maybe U2401 broken pins that goes to cpu. Remove U2401 and measure GND resistance D1 D2 D3 D9 E1 E4 F1
Page generated in 0.20481 seconds with 9 queries
