03-14-2017, 13:30 | #1 (permalink) |
Junior Member Join Date: Nov 2016
Member: 2645877 Status: Offline Thanks Meter: 0 | iPhone 6 Serial Number change Is it possible to change just the Serial number on the 64bit NAND, just using the cable below and the WL software. DCSD USB cable for WL 64Bit iphone |
03-31-2017, 23:37 | #4 (permalink) |
Member: 2645877 Status: Offline Thanks Meter: 0 | I didn't think the iPhone 4 board could read the 64bit Nand. From what I can see they are using a iPhone 6 board in the jigs with its original Nand. Then they swap the Nand with one from another board and then program that. I might be wrong, but that is what it looks like is happening. |
04-01-2017, 03:27 | #6 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2693480 Status: Offline Thanks Meter: 0 | make test point ( using email cable /jumper based board iphone3.1 limera1n exploit to destination nands iphone 6 ) or cable using ufd pcba for this method with special cable for sure |
04-01-2017, 16:48 | #8 (permalink) |
Member: 2693480 Status: Offline Thanks Meter: 0 | tinypiccom/ r / jzb12b / 9 make sure logic iphone3,1 ( iphone4 board ) removed ; nands,baseband 1,2 ( just for media jamper and detect logic ip6 board)..detail about this methode , i will explain next because much explain and step for this process Last edited by tuanraja; 04-01-2017 at 16:55. |
07-04-2017, 08:52 | #13 (permalink) |
No Life Poster Join Date: May 2016 Location: 574 Age: 31
Member: 2567774 Status: Offline Thanks Meter: 255 | This method of changing serial works very well with WIFI iPads. Only hardware way to remove iCloud. Cellular iPads are easy by removing 1 or 2 capacitors Sent from my SM-G530T1 using Tapatalk |
07-05-2017, 07:35 | #14 (permalink) | |
Crazy Poster Join Date: Jul 2016 Location: shenzhen,china
Member: 2601523 Status: Offline Thanks Meter: 19 | DCSD cable for iphone serial number Quote:
DCSD USB cable for WL 64Bit iphone hdd test fixture engineering line Phone Repair Cable | |
