02-11-2016, 12:56 | #1 (permalink) |
No Life Poster Join Date: Mar 2013 Location: Nepal Age: 41
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | iphone 6 short after installing pmic (need help) phone was in touch problam,i reball touch is and not done,then i reball pmic. now phone is short. i change pmic also but no luck. for check pm ic i install pmic in to other working phone and that was also dead ans short. short on that cap showing in pic. please help me to solve this problam. thanks |
The Following User Says Thank You to KE6SOLTI For This Useful Post: |
05-07-2017, 13:48 | #13 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2106911 Status: Offline Thanks Meter: 67 | in my case no it's not a board for repaire i have a few board for test they have no value for me so i can be less carrfule in this case if you have short on PP_GPU or PP_CPU or PP_VARSOC you have to remove all on those lines capacitor resistor ,etc and let only the CPU if the short is not gone that meens it's under the CPU you can use two methode i never succed on those cause i m not finished yet remove the undefil around the CPU ( 290° C air flow 70 1,5 cm) and remove the first layer of the CPU (SDRAM) (325°c same aire flow 1cm ) remove again the underfil wich is still on the second part of the CPU (still welleded on the board ) same heat values and gentelly remove the CPU (be carrfull of not damages pads) then clean all underfill check for all if they are not short clean CPU both side and SDRAM .. reball the CPU and the SDRAM and put them back in place (i repeat i never dont this part ).. i'm not an expert i do that only as hobby . if it's you board go it's good way to practice if not don't !! i you have damaged a custumer board friend the honnesty is to by him an other one !! |
