01-04-2018, 10:12 | #19 (permalink) | |
Freak Poster Join Date: Sep 2008 Location: Poland Age: 35
Member: 863309 Status: Offline Sonork: 4540726 Thanks Meter: 41 | Quote:
"fdrtrustdata" on 3uTools But i do restore from iTunes in DFU mode and working fine. | |
05-08-2018, 22:29 | #20 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2474430 Status: Offline Thanks Meter: 3 | Exact same issue here. Dies 20% in 3u sending FDRTrustData. Stuck in itunes forever. Don't have a nand programmer but I know someone who does. gotta be a bad nand, I'd think. |
05-11-2018, 09:07 | #21 (permalink) |
Junior Member Join Date: Nov 2008 Location: Italia Age: 45
Member: 909257 Status: Offline Thanks Meter: 1 | I had the same problem after changing the display and the home button. The phone worked perfectly for a week, after the phone got stuck in the boot loop. I tried to flash the firmware with 3uTools because I did not want to lose my data (basically my photos) because unfortunately I did not make a backup, but I stay still or at 20% or 38% where I read "writing filesystem". Has anyone managed to solve keeping the data? |
04-26-2019, 19:17 | #24 (permalink) | |
Freak Poster Join Date: Jul 2013 Location: karimnagar
Member: 1986680 Status: Offline Sonork: 7210 Thanks Meter: 21 | Quote:
i just removed a shorted capacitor near nand and it worked. hope it works for you Thankyou | |
09-23-2019, 16:24 | #25 (permalink) |
Junior Member Join Date: Sep 2019 Location: 3rd rock from the Sun
Member: 2929049 Status: Offline Thanks Meter: 0 | Hopefully it's okay to jump into this thread as it's the same topic as I was going to post. I have an iPhone 7 stuck in a recovery loop. Using 3u, it gets stuck at Sending FDRTrust Data. I've tried using recover mode as well as putting the phone in DFU mode. In iTunes, it gets stuck at verifying update/verifying restore. Has anyone had any success in resolving this issue? Is there anything I can try? Not afraid to open the phone (already have replacement adhesive seals ready). Where does 3u send this information (RootTicketNORData, FDRTrustData, etc.)? |
10-04-2019, 15:59 | #26 (permalink) |
Junior Member Join Date: May 2007 Location: Metz, France
Member: 518225 Status: Offline Thanks Meter: 0 | Hi all, Have same problem here (stuck on sending FDRTrust data) while trying to restore an ipad Air 2 after unsucessful upgrade to iPadOS 13...went to the local Apple premium reseller, and they couldn't update it neither... I tried with ITunes, 3utools and idevicerestore...does anyone have an idea how to fix this ? |
10-07-2019, 11:02 | #28 (permalink) |
Member: 2929049 Status: Offline Thanks Meter: 0 | What does this mean exactly? Is it that the NAND is physically faulty and needs to be swapped out, or is it that the NAND needs to be reflashed (and thereby creating a new phone with a new IMEI)? How do iDevices end up in this state in the first place? |
12-16-2019, 20:33 | #29 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | i have this problem on iphone 8 plus came with stock on logo..when i try to restore in 3utools its stock on sending fdrdata and yes in itunes its stocks forever without error..i change the nand just to test if that is the prob and yes it restores fine with the other nand from a donor iphone 8 plus board..but it did not activate because of serial issue..so yes i confirm this problem is related to nand.. |
