04-10-2015, 17:06 | #1 (permalink) |
Freak Poster Join Date: Dec 2006 Location: canada
Member: 404967 Status: Offline Thanks Meter: 33 | iphone 6 temperature any solution |
The Following User Says Thank You to walidprestige For This Useful Post: |
04-12-2015, 18:13 | #4 (permalink) |
Freak Poster Join Date: Nov 2014 Location: Germany
Member: 2289832 Status: Offline Thanks Meter: 48 | First change battery. 2. Feel for heat on mainboard. 3.check r1308 r1310 r1390 r1357 they show around 10 kohm if not replace. 4. check c1367 c1359 c1322 c1368 If short replace them. 5. rehot/reball/replace pmu. Any of these will solve your problem sure |
The Following User Says Thank You to kaptanci For This Useful Post: |
09-13-2015, 19:15 | #14 (permalink) |
Junior Member Join Date: Sep 2008
Member: 860344 Status: Offline Thanks Meter: 3 | Thanks for answer about this question, i check first mb not heats up anywhere all what i find, i checked voltage on BATTERY SWI_CONN is different becaouse normal shoul be around 2V i have 1,1V and when i touch this connection temperature message was gone So i order SN2400B0YFF U1401 i will posted after replace part. Thanks |
09-17-2015, 08:19 | #15 (permalink) |
Member: 860344 Status: Offline Thanks Meter: 3 | After U1401 replaced same issue any ideas? U2201 checked is not heating up. Temperatures ok, temp sensors checked ok, no shorts all looks good, PMU after rehot.. |
The Following User Says Thank You to siuras676 For This Useful Post: |
