Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 12-12-2016, 19:42   #1 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 71
iphone 6 touch screen freeze..but...
...but unfreeze if detach front camera flat cable.
i explain...
iphone 6 sometimes works,then freeze or start commands itself,
changed display set and all same,
i try whit another one and works good,so i fix home key,screws,front cam whit audio and sensors.
i try and...touch freezed ,
make me crazy,
i try to use old display and it works
so step by step i understand the touch screen works only if the front camera flat is detached from board
changed flat camera and is the same,phone freeze and cant use touch screen,
tryed to isolate contacts,components and nothing.
what i can do for solve?
no teardown,no water,all original parts.
thnk friends.
ps
the touch screen works again after remove the front camera flat only if shut off the screen or disconnect and reconnect battery.
Old 12-12-2016, 20:40   #2 (permalink)
Member: 2320407
Thanks Meter: 87
Your problem is easy with me !
your problem is (TOUCH Freeze or stuck when connecting FRONT CAM) why ? you have problem in synchronization between CUMULUS IC CHIP and proximity all this is found in these SIGNALS
1-CUMULUS_TO_PROX_RX_EN_1V8
2-PP1V8_GRAPE
so to sum up
check the following:
1-C1158
1-FL1158
they are linked to PIN number 25 from J1111
then test R2405 this is very important it's responsible to SYNC between Proximity sensor which is on FRONT CAM FLEX and CUMULUS TOUCH IC
See the following photos
they must have 1.8 VOLT when testing with multi-meter !
2-PP1V8_GRAPE
Adonis IRAQI was here
Kind Regards
The Following 5 Users Say Thank You to ctccellulaire For This Useful Post:
Page generated in 0.19240 seconds with 7 queries
