05-30-2017, 11:21 | #1 (permalink) |
Freak Poster Join Date: Dec 2015 Location: nigeria .benin
Member: 2495283 Status: Offline Sonork: gsmvilla.com Thanks Meter: 12 | Iphone 6 very hot 120amps Sent from my iPhone using Tapatalk Pro |
05-30-2017, 13:28 | #2 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Earth
Member: 813803 Status: Offline Thanks Meter: 120 | L1503 marries VCC_MAIN and PP_WLED_LX which goes to D1501 and U1501 - Check how much voltage is on VCC_MAIN - Check for short on C1505 OR C1531 OR C1530 (PP_LCD_BL_ANODE) to ground I think you have short on backlight circuit |
05-30-2017, 15:04 | #3 (permalink) | |
Member: 2495283 Status: Offline Sonork: gsmvilla.com Thanks Meter: 12 | Quote:
This three caps have no shot????? Sent from my iPhone using Tapatalk Pro | |
05-31-2017, 05:01 | #4 (permalink) | |
Freak Poster Join Date: Jan 2014
Member: 2106911 Status: Offline Thanks Meter: 67 | Quote:
so this short is through some arround questions : are you sure that's is L1503 wiche is hot or U1502 (this is related to GND) have checked the other side of this board maybe something else is hot check C1263 and C1200 | |
05-31-2017, 05:06 | #5 (permalink) | |
So u mean L1503 cannot be shot because its Gnd U1502 is hot also but not as L1504 Sent from my iPhone using Tapatalk Pro | |
05-31-2017, 05:19 | #6 (permalink) | |
so the caps can be short, the ic can be short ,but the coil can't directly shorted see your schematic you will figure it out so if L1503 is hot and the amperage is so hight that's meen VCC_main short check both side of the board question what is the diode mode value on TP2520 ?? it had to be around 500 mv check this | |
The Following User Says Thank You to vinse For This Useful Post: |
