01-26-2017, 22:12 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | iphone 6 waiting for iphone error 4005 done Unit : iphone 6 Problem : Dead the board was clean and no indication of repair and also not shorted reading RPS 0.07 to 0.08 Replace : U1700 (U2) failed Replace : U1401 (Tristar ic) Failed Replace : U1400 failed in this case indication of 0.07 to 0.08 reading on power supply 80 % U2 or U1700 cause of the problem base on my experience so i decided to change U1700 but im not lucky to do it the same also by another ic i've been remove Testing Digital Power Supply after changing ic and testing program im not lucky still waiting for iphone on itunes here is those ic's i remove so i decided to remove nand ic and reball and tesing again but again ? im not luckystill (waiting for iphone ) at end after removing the usb cable from phone its show error 4005 so i proceed to program the nand ic and write under laying data and restore back up data restore backup after programming and restore on itunes im lucky and there is progress re-assemble the nand here the finish product if this post can help you ? thanks button is enough |
The Following 18 Users Say Thank You to maxieboy For This Useful Post: |
01-28-2017, 15:07 | #4 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | very useful post. I recently purchased WL64 bit Nand programmer. I am a bit confused regarding formatting the NAND chip. There is only backup and program option but i dont know if i can format the chip. And a lot of times i am unable to program 5s Nands it says that it doesnt has kernel in it and something like that. Can you please help me regarding this wl product. Thanks. |
The Following User Says Thank You to CDMA_RASHID For This Useful Post: |
01-28-2017, 22:41 | #5 (permalink) | |
Member: 302596 Status: Offline Thanks Meter: 784 | Quote:
The Following User Says Thank You to maxieboy For This Useful Post: |
06-01-2017, 14:20 | #8 (permalink) |
Freak Poster Join Date: Jan 2004
Member: 48755 Status: Offline Thanks Meter: 30 | Hi all thanks for this useful post I have an iPhone 6 plus with the same problem. not detected at all by the computer. but when I force DFU mode, it boots up into DFU but when I start to restaure, it disconnects and never come back. It turned out to be the NAND. I removed it, and tried to read it with IP-BOX but it was like erased !! thats what IP-BOX said I re write the data from default values, but with the correct serial number. Now the phone is detected normally when plugged but it fails the restore with error 2005 any idea ? |
07-05-2017, 04:35 | #10 (permalink) | |
Crazy Poster Join Date: Jul 2016 Location: shenzhen,china
Member: 2601523 Status: Offline Thanks Meter: 19 | Re:iphone 6 waiting for iphone error 4005 done Quote:
hello, dear friends, the WL 64bit programmer can format the nand, you need re-write underlying the data | |
07-05-2017, 06:15 | #11 (permalink) |
Freak Poster Join Date: Mar 2017
Member: 2691507 Status: Offline Thanks Meter: 100 | Humm, this makes "IP Box 2" look real bad since I have two dead ipad air 2 because of this. If when I get the new Nands from China (with sn) then if the ipads successfully get restored I'm trashing IP Box 2 "for real" and not buying anything from them anymore not matter how cheap they are. I have used IP Box 2 successfully with old iphone and ipad but no luck with new, I was able to restore an ipad mini 4 just because I wrote the sn on top of the already programmed Nand without formatting. |
07-12-2017, 10:39 | #12 (permalink) |
Member: 302596 Status: Offline Thanks Meter: 784 | @cisco2017 well ipbox is also good, its up to you how to handle it, i post a lot of guide regarding ipbox try to read it may be it will help you too |
08-10-2017, 08:21 | #13 (permalink) | |
Insane Poster Join Date: Apr 2014
Member: 2171747 Status: Offline Thanks Meter: 10 | Quote:
Why Blame the box when it can potentially be you who's not patient enough to actually figure out how it works and you want to give up and trash it Sent from my iPhone using Tapatalk Pro | |
