03-13-2019, 14:48 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: India(Sikkim)
Member: 311436 Status: Offline Thanks Meter: 38 | iphone 6plus no display after lcd change please help me out |
03-17-2019, 08:07 | #2 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | While the screen is connected try touching the CHESTNUT Chip and see if it is heating. If it heats your need to change the CHESTNUT. You can even check if the touch connector on motherboard is damaged. And make sure the touch connector is properly connected while conmecting the LCD. Hope that helps. |
03-21-2019, 15:33 | #5 (permalink) |
Junior Member Join Date: May 2016 Location: Italy
Member: 2568440 Status: Offline Thanks Meter: 4 | Have you checked the backlight circuit? If you do not disconnect the battery when you mount or disassemble the display you can interrupt the power supply of the backlight. |
04-26-2019, 19:22 | #8 (permalink) | |
Freak Poster Join Date: Jul 2013 Location: karimnagar
Member: 1986680 Status: Offline Sonork: 7210 Thanks Meter: 21 | Quote:
did you check the strip connector properly. and just inspect holes near display connector..if itz drilled with the long screw..you have to join the tracks(retrack it) | |
