11-05-2017, 22:00 | #1 (permalink) |
Insane Poster Join Date: Nov 2012
Member: 1836029 Status: Offline Thanks Meter: 9 | iPhone 6S PP1v8 partial short 500ohm There was short on VCC_MAIN after removing C5283_RF short was gone. I replaced C5284_RF as well. I checked other lines before tried to power it on and found out that PP1V8 line has good reading in diode mode about 270 (same as in good phone) but resistance on that line is too low ( 505ohm ) with comparison to good motherboard (> 37kohm). Anyway phone powered up ( there was 1.8V on PP1v8 ) and was working fine but time to time turned off - LCD went black no image no backlight - so checked backlight and LCD chestnut circuit but all readings are the same as in good motherboard. So my assumption is that there is something wrong with PP1V8 line (it is connected to LCD as well). I removed FL3104, FL3220, FL4205 and by doing that disconnected some capacitors on PP1V8 around LCD, back and front camera connectors. No change still low resistance on PP1v8 line. I removed some capacitors on PP1v8 line: C0900, C1322, C1323 no change still low resistance I realized that sometimes if LCD was not connected I had about 3.8V on PP1V8 line so after checking schematics again realized that maybe power IC is damaged in some way (partially shorted PP1v8 line) and decided to remove power IC U2000. Unfortunately no change still low resistance on PP1v8 line (500ohm) Did someone had similar issue and can help? Last edited by czesk20; 11-05-2017 at 22:09. |
11-06-2017, 18:59 | #3 (permalink) |
Freak Poster Join Date: Mar 2013 Location: Greece Age: 35
Member: 1903358 Status: Offline Thanks Meter: 146 | PP1V8 is produced from u2000, and goes to NAND & CPU So you have to check one by one. Unfortunately i did not have this problem yet to help you more. |
03-03-2019, 01:57 | #5 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: In a point from Universe! Age: 40
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | Quote:
ways you have when you take measurements in diode mode? Also did you tried to power supply that line with external 1.8V? | |
