Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 06-08-2018, 12:35   #1 (permalink)
kali_fuchi's Avatar
Member: 1705433
Sonork: kali
Thanks Meter: 45
Arrow iphone 6plus touch issue
dear friends,i have facing the problem in iphone 6 plus touch not working. already changed u2401 and u2402 both touch ic, make m1 jumper for track damaged. after changed all component touch start work 2 hour, then again stop work with some squre bars in display. please share someexperience.
Old 06-13-2018, 09:02   #2 (permalink)
Member: 1733753
Sonork: 100.1627554
Thanks Meter: 4
Supoose to be still have problem with touch ic. Reball or change touch ic qnd hopefully it should be work again
Old 06-13-2018, 14:55   #3 (permalink)
Member: 2142442
Thanks Meter: 53
If you remove white digitizer ic you have to measure pins that goes to cpu!
Old 06-13-2018, 15:48   #4 (permalink)
Member: 1211915
Sonork: 345634564
Thanks Meter: 93
sTEP 1 - check values of all pads (diode mode)
step 2 - check all voltages and power supply
step 3- USE Original TOUCH IC from other phone
step 4 - user Original Lcd to test
Old 06-21-2018, 21:06   #5 (permalink)
Member: 1696994
Thanks Meter: 24
did you get this iphone repaired
Old 06-22-2018, 10:16   #6 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
My experience with square lines after replace as in your case both 2 ics, is with u2401.
- i've remove u2401 than power on the phone and if square lines don't appare i know that this is the problem..
so at the time i did new reball or replace with correct ic (u2401) alignment and solve.
the chassis is ok , is crooked or deformed? because if the sockets where the m.board is laid are not perfectly aligned the problem will reoccur as long as they have been welded well.
Page generated in 0.13390 seconds with 8 queries
