Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 12-30-2017, 22:27   #1 (permalink)
Member: 1959885
Thanks Meter: 6
iPhone 6s dead 80ma
I got a iPhone 6s with water damage. after perfect clean the board i press power button. the current gets up to 120ma after and go down to 80ma and stay there. Nothing gets warm.
where should I search first.
Thanks a lot for your help
The Following User Says Thank You to Joe025 For This Useful Post:
Old 12-31-2017, 22:52   #2 (permalink)
Member: 32369
Thanks Meter: 5
Always start the check for short on VCC Main and VBat line
The Following User Says Thank You to The Magpies For This Useful Post:
Old 12-31-2017, 23:16   #3 (permalink)
Member: 1191636
Thanks Meter: 6
hello
i have iphone 6s damage
the current 0-20-80ma and return
Old 01-01-2018, 21:50   #4 (permalink)
Member: 1959885
Thanks Meter: 6
VCC Main no shot and ok. VBat at TP02/TP03 is ok.
Old 01-02-2018, 22:01   #5 (permalink)
Member: 2498972
Thanks Meter: 33
Now that you have checked the main power lines, you need to check ALL of the outputs from the PMIC and then the BB_PMU. Look for shorts and work your way from there.
The Following User Says Thank You to minho For This Useful Post:
Old 01-03-2018, 01:37   #6 (permalink)
Member: 2753739
Thanks Meter: 7
I had iPhone like this the water damage under chistnut I replaced it and backlight driver
Try to remove those drivers and try to boot this iPhone
Hope to help
The Following User Says Thank You to Hawy56oo6 For This Useful Post:
Old 01-03-2018, 02:31   #7 (permalink)
Member: 1959885
Thanks Meter: 6
Thank you for your reply. I will check the Voltages and Post it here.
Old 01-03-2018, 21:17   #8 (permalink)
Member: 1959885
Thanks Meter: 6
I checked Voltage...
I got no PP_GPU an at C2012 -C2021 12 Ohm to Grund.
Old 01-03-2018, 23:34   #9 (permalink)
Member: 2498972
Thanks Meter: 33
That seems okay. You cannot measure the voltage of PP_GPU unless the screen is "on". That means plug the logic board to a Lightning cable and then check the voltage.
Old 01-05-2018, 11:31   #10 (permalink)
Member: 1959885
Thanks Meter: 6
Ok I got the Voltage from the PMIC:
PP_CPU 1,8V
PP_GPU 0V
PP_SOC 0,7 V
PP1V8_SDRAM 1,8V
PP1V1_SDRAM 1,1V
PP3V3_USB 3,3V
PP1V8_VA 1,8v
PP3V0_TRISTAR 2,9V
PP0V8_OWL 0,8V
PP3V0_NAND 3,0V
PP3V3_ACC 0V !!!
PP3V0_PROX_ALS 2,9V
PMU_LDO8 0V !!!
PP2V85_CAM_AVDD_PMU 0V!!!
PP0V9_NAND 0,9V
PP3V0_PROX_IRLED 3,4 V
PP1V8_ALWAYS 1,8V
PP3V0_MESA 3,0V
PP1V2 1,2V
PP1V8_MESA 1,8V
Old 01-05-2018, 14:42   #11 (permalink)
Member: 2498972
Thanks Meter: 33
PP_CPU 1,8V
PP_GPU 0V
PP_SOC 0,7 V
PP1V8_SDRAM 1,8V
PP1V1_SDRAM 1,1V
PP3V3_USB 3,3V
PP1V8_VA 1,8v
PP3V0_TRISTAR 2,9V
PP0V8_OWL 0,8V
PP3V0_NAND 3,0V
PP3V3_ACC 0V !!!
PP3V0_PROX_ALS 2,9V
PMU_LDO8 0V !!!
PP0V9_NAND 0,9V
PP1V8_ALWAYS 1,8V
PP3V0_MESA 3,0V
PP1V2 1,2V
PP1V8_MESA 1,8V
You don't need to worry about PP3V3_ACC, it's only on for a brief moment at the very beginning. However you need to check PMU_LDO8 & PP2V85 for shorts.
Old 01-05-2018, 15:40   #12 (permalink)
Member: 1959885
Thanks Meter: 6
ok... but are this Voltages ( PMU_LDO8 & PP2V85) necessary for boot up the board?
Old 01-05-2018, 16:01   #13 (permalink)
Member: 2498972
Thanks Meter: 33
I'm not sure about LDO8, it doesn't seem to go anywhere according to the schematic. As for the 2V85, it's not necessary. I would also check the U_PMU_RF to see if the voltages are present.
Old 01-09-2018, 15:42   #14 (permalink)
Member: 1959885
Thanks Meter: 6
Do you mean this voltages at u_PMU_RF
Old 02-22-2018, 08:54   #15 (permalink)
Member: 1959885
Thanks Meter: 6
Now i checked the Voltage at U_PMU_RF
i got no output Voltage on
C3609_RF
C3610_RF
C3611_RF
C3612_RF
C3613_RF
Now the Problem is on U_PMU_RF ?
Page generated in 0.78037 seconds with 8 queries
