11-04-2017, 00:13 | #1 (permalink) |
Insane Poster Join Date: Nov 2012
Member: 1836029 Status: Offline Thanks Meter: 9 | iPhone 6S - 2sec touch lag/freeze after power button pressed Also if I have screen lock disabled and I don't touch LCD for about a minute and later I try to swipe, screen won't react is frozen for 1-2sec. |
11-15-2017, 18:32 | #2 (permalink) |
Member: 1836029 Status: Offline Thanks Meter: 9 | When I disconnect 3D touch/home button connector from logic board touch screen works perfect it's NOT unresponsive. When the 3D touch connector is plugged in but home button disconnected (bottom socket on LCD) issue still exists touch screen is not working properly (lag). So I though that maybe there is some issue with 3D touch itself. Then I tried 2 other brand new 3D touch-es and it's the same. Problem still exists. As I mentioned before it's genuine iPhone 6S LCD It's NOT a problem with motherboard as other 2 screens that I tested work perfectly good with this logic board. It looks like there is maybe some problem with communication between 3D touch and LCD module. Did anybody have similar issue and can help? |
11-16-2017, 18:10 | #3 (permalink) |
Junior Member Join Date: Dec 2009 Location: Netherlands, Gelderland
Member: 1190472 Status: Offline Thanks Meter: 9 | Have same problem with a 6s with a aftermarket screen and touch-id enabled. If you disable touch-id in setting the problem is gone in my case. If you have the same and freezes are gone when disabled you probably have a aftermarket screen. |
