04-22-2017, 17:41 | #1 (permalink) |
Freak Poster Join Date: Oct 2010
Member: 1422282 Status: Offline Thanks Meter: 23 | Iphone 6s back filter replacement.. Sent from my iPhone using Tapatalk |
04-22-2017, 21:30 | #2 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2106911 Status: Offline Thanks Meter: 67 | us an iron with small tip to tint your pads and after that use hot air to solder your filter this is for the soldering part and please read again your filter name .the annode one on 6S is FL4211 but i think your wrong about this filter if you removed it and the short gone it's not the filter the issue !!! the filter can't be shorted check bothe pads on eache side onnthe filter your short is still theire on one side if it's on the left side that's meen C4211 is shorted (remove replace ) if its the right side that is more difficulte check C4022 C4023 yours diods (they are two) and the PP_VCC_MAIN caps and check your backlight driver at this end if by miracle they are not short still so you can jump your filter and solder it on TP22 for on side and the other side on C4023 (not the GND side ) thats will be ok |
04-22-2017, 21:45 | #3 (permalink) | |
Member: 1422282 Status: Offline Thanks Meter: 23 | Quote:
Thx for your reply. Sorry about wrong filter name. You are right its FL4211. I think i misunderstood about this short concept.if you can clear bit confusion for me it would be appreciated. When i test the pads of the filter with ground it beeps from one side but it doesn't beeps from other side of the pad. So thats mean there is shortage in the backlight circuit? I shouldn't get any beep from any side of the filter pad with the ground right? I didn't checked it with the line connector yet. In order check shortage do i need to test cap with connector line in continuity? For example if i connect one prob to lcd connector anode line n one to the filter n if i ill get beep the filter is short or not? Sent from my iPhone using Tapatalk | |
The Following User Says Thank You to shani1122 For This Useful Post: |
04-22-2017, 22:37 | #4 (permalink) |
Member: 2106911 Status: Offline Thanks Meter: 67 | hello if it's beep so the short still theire paye attention on wich side is it and follow my instructions a filter never be shorted caus its not connected to the GND !! |
The Following User Says Thank You to vinse For This Useful Post: |
04-23-2017, 04:52 | #14 (permalink) |
Insane Poster Join Date: May 2013
Member: 1929960 Status: Offline Thanks Meter: 27 | he got it with no backlight probably because someone tried to replace screen and did not unplug battery and simply shorted the anode pin when plugging in the new LCD. this is the majority of cases with FL4211 failure caused by techs. The backlight circuit is usually OK, just the filter did its job and died. jump it and it should be fine |
04-23-2017, 05:15 | #15 (permalink) |
Member: 2106911 Status: Offline Thanks Meter: 67 | you right about usual issue on FL4211 but read the first post the FL4211 was shorted for him (beep on diod mode to GND ) so he remove the filter ( but a filter can not be shorted only ****ed ) so he tested each pads of this filter on side still short it's he's backlight circuit wich is shorted he had to find he's short first fix this and finish by the FILTER and the jumper is not a good solution cause filter act like fuse so it **** to protect the circuit so if you jump next issue the damages will be bigger |
