05-18-2017, 17:15 | #1 (permalink) |
No Life Poster Join Date: Jul 2016
Member: 2598526 Status: Offline Thanks Meter: 52 | iPhone 6s backlight issue after water damage No backlight so replaced u4020 still nothing. Diodes are good, filters are good. Both coils have resistance that correspond to the schematic so presuming those are good. There's no voltage boosting Can someone test voltage at R4020 in a working 6s? It's a clock signal and I get 0v not sure if that should be 1.8v or not |
05-18-2017, 18:32 | #3 (permalink) | |
Member: 2598526 Status: Offline Thanks Meter: 52 | Quote:
Yes the big cap C4023. Do you know why the 6s uses two different diodes and coils? Does the backlight switch from a low/high power function at some point? Trying to figure out if backlight would work if only one of the coils/diodes were in circuit or if both need to be | |
The Following User Says Thank You to short_toground For This Useful Post: |
05-19-2017, 11:45 | #5 (permalink) |
Freak Poster Join Date: Sep 2015
Member: 2453408 Status: Offline Thanks Meter: 63 | maybe there is more diodes in lcd so its using 2 coils to get more current, or maybe diodes are different in 6s, I dont know. Still you dont need to change IC in water damage because its glued, problem is not in IC but somwhere around it |
05-19-2017, 11:51 | #6 (permalink) |
Member: 2598526 Status: Offline Thanks Meter: 52 | Do you have a working one to test voltage at R4020? Need to know if during operation it's 1.8v or not Mine is 0v but schematic shows it's a clock signal so I imagine it shouldn't be 0v but can't verify 1.8v sdram trigger is present Sent from my iPhone using Tapatalk |
05-19-2017, 13:12 | #8 (permalink) | |
Thanks for measuring that I appreciate it. I couldn't measure for ac voltage at the switching side? Do you know if backlight will work with only one diode/coil or needs both sets? Thanks again | |
05-19-2017, 13:59 | #11 (permalink) |
Member: 2453408 Status: Offline Thanks Meter: 63 | No backlight nothing just 400mA and then 18ohm on vcc_main. But if you think on it for a while then you have that coil which is charged by IC and then discharged through diode. If you have no diode then coil is pumped to very high voltages and damages transistors in SW1/SW2, thats probably what happened there. But thinking is not my strong point today, its too hot . |
05-19-2017, 14:01 | #13 (permalink) | |
Member: 2598526 Status: Offline Thanks Meter: 52 | iPhone 6s backlight issue after water damage Quote:
Lol yeah hot here too. I wonder if both the smaller diode and coil were removed if backlight would work with just the bigger coil and diode. But yeah at this point idk what to look for. Do you know if anything else enables the ic to switch besides 1.8vsdram? Are the coils and diodes from a 6 compatible with 6s? I know they use different ic's | |
05-19-2017, 14:15 | #14 (permalink) | |
Member: 2453408 Status: Offline Thanks Meter: 63 | Quote:
