03-20-2018, 17:18 | #1 (permalink) |
Junior Member Join Date: Jul 2009 Location: Jonquiere Qc Canada Age: 32
Member: 1071201 Status: Offline Thanks Meter: 4 | iPhone 6s Backlight PP_GPU Short - Not ic,not filter,not coil Then i replaced all backlight kit. All new. U4020 / D4020 / L4021 / D4021 / L4020. New ic,no short on C4020 but still no backlight. Then i found another short on PP_GPU. All the caps on that line(PP_GPU)are beeping. Anyone have an idea that what could it be? Thanks in advance. |
03-20-2018, 18:59 | #2 (permalink) |
Freak Poster Join Date: Oct 2016
Member: 2634857 Status: Offline Thanks Meter: 25 | PP_GPU is low resistance line abt 35 ohms so will beep its a low power line so 35ohms over 1v or so line is not shorted.... Hope this helps before pulling any more components off the board.... Sent from my X98 Plus 3G using Tapatalk |
03-20-2018, 21:03 | #4 (permalink) | |
Member: 1071201 Status: Offline Thanks Meter: 4 | Quote:
Thank's for the information,so if i don't have a GPU short,i'm kind lost. I measured TP1120 and i have 8,2ohms,anyway i don't know waht to do about that info. | |
03-21-2018, 10:46 | #6 (permalink) |
Member: 2634857 Status: Offline Thanks Meter: 25 | Voltage readings on i6 diode mode on PP_GPU. First to check PMU IC output 11 way voltages: PP_CPU 0.775V-1.0V = 148mv PP_VAR_SOC 0.9V-0.95V = 335mv *PP_GPU 0.9V-0.95V = 0.92mv / 52.6ohms PP1V8_SDRAM 1.8V CPU = PP1V2_SDRAM 1.2V CPU = PP0V95_FIXED_SOC 0.95V CPU = PP1V8 1.8V CPU PP1V2 1.2V PP1V2_OSCAR 1.2V PP1V8_OSCAR 1.8V PP1V8_GRAPE 1.8V if all working fine, to check CPU 11 way voltages: PP3V3-USB覧A8 CPU = 528mv PP1V8_VA_L9_L67覧U0900、U1601 PP3V0_TRISTAR覧U1700 USB PP3V0_IMU覧U1901 PP3V0_NAND覧U0604 PP3V3_ACC覧U1700 USB PP3V0_PROX_ALS覧J111 PP1V0覧A8 CPU PP3V0_PROX_IRLED覧J111 PP1V8_ALWAYS覧A8 CPU PP3V0_MESA覧U2100 Hope this helps . Sent from my X98 Plus 3G using Tapatalk |
The Following 3 Users Say Thank You to deegee2016 For This Useful Post: |
03-21-2018, 17:04 | #8 (permalink) |
Member: 2634857 Status: Offline Thanks Meter: 25 | I'm giving him an idea how to go abt things , check your power rails first...same principle whether or not i6 ,6s etc. Sent from my X98 Plus 3G using Tapatalk |
The Following User Says Thank You to deegee2016 For This Useful Post: |
03-23-2018, 17:07 | #10 (permalink) |
Member: 2634857 Status: Offline Thanks Meter: 25 | Hi mate if you can wait a few will provide testing steps for you later. For backlight and image circuit ... Sent from my X98 Plus 3G using Tapatalk |
03-23-2018, 18:27 | #11 (permalink) |
Member: 2634857 Status: Offline Thanks Meter: 25 | deegee www.dgpcrepairs.co.uk Backlight Test Sequence i6s (820-5507) STEPS: 1- Test with other LCD and also try original or known good 2- Check the BackLight coils: TEST OPEN CIRCUIT FL4211 - PP_LCM_BL_ANODE FL4212 - PP_LCM_BL_CAT1 FL4213 - PP_LCM_BL_CAT2 3- Check the Capacitors: C4211 - PP_LCM_BL_ANODE_CONN C4212 - PP_LCM_BL_CAT1 C4213 - PP_LCM_BL_CAT2 4- Continuity Test: J4200 (TEST FROM INOMING SIDE TO J4200 PIN) FL4211 - PP_LCM_BL_ANODE FL4212 - PP_LCM_BL_CAT1 FL4213 - PP_LCM_BL_CAT2 C4211 - PP_LCM_BL_ANODE_CONN C4212 - PP_LCM_BL_CAT1 C4213 - PP_LCM_BL_CAT2 5- Check the Components: The voltage on these component must be VCC_MAIN voltage (3.7 ~ 4.1) V . C4020 - PP_VCC_MAIN C4021 - PP_VCC_MAIN L4020 - PP_VCC_MAIN L4021 - PP_VCC_MAIN 6- Check the Capacitors: SHORT CIRCUIT/LEAK C4022 - PP_LCM_BL_ANODE C4023 - PP_LCM_BL_ANODE 7- Check the Diode: OL / >20V D4020 D4021 8- Check the Components: I2C BUS DATA - IF RESISTORS ARE DAMAGED THE BUS WONT FUNCTION AS IT WILL BE HELD LOW, NEEDS TO BE HIGH R4020 - DWI_PMGR_TO_BACKLIGHT_SCLK C4026 - I2C0_AP_SDA C4024 - I2C0_AP_SCL C4025 - I2C0_AP_SCL_MUON R4021 - I2C0_AP_SCL If all above is ok then: 9- Re-ball or replace ( U4020 ) the BackLight IC. Regards Dee Sent from my X98 Plus 3G using Tapatalk |
03-23-2018, 18:28 | #12 (permalink) |
Member: 2634857 Status: Offline Thanks Meter: 25 | deegee COPYRIGHT 2016 www.dgpcrepairs.co.uk No Image Test Sequence i6s (820-5507) STEPS: 1- Test with other LCD and also try original or known good 2- Check the LCD connector (J4200) Resistances on pins MAIN SUPPLY (IF DEVICE BOOTS THEN THIS IS OK) 3- Check: - MAIN SUPPLY ( VCC_MAIN = 3.6 ~ 4.2 Volts ) C4000 - VCC_MAIN L4000 - VCC_MAIN 4- Check: PP6V0_LCM_BOOST = (6.0 volts) C4007 - PP6V0_LCM_BOOST C4008 - PP6V0_LCM_BOOST 5- Check: PN5V7_LCM_MESON_AVDDN = (5.7V /- volts) C4001 - PN5V7_LCM_MESON_AVDDN C4006 - PN5V7_LCM_MESON_AVDDN FL4207 - PN5V7_LCM_MESON_AVDDN C4207 - PN5V7_LCM_MESON_AVDDN 6- Check: PP5V7_MESON_AVDDH = ( 5.7 Volts /+ ) C4005 - PP5V7_MESON_AVDDH FL4208 - PP5V7_MESON_AVDDH C4208 - PP5V7_MESON_AVDDH 7- Check: PP5V7_LCM_AVDDH = ( 5.7 Volts /+ ) C4004 - PP5V7_LCM_AVDDH FL4200 - PP5V7_LCM_AVDDH C4200 - PP5V7_LCM_AVDDH C4201 - PP5V7_LCM_AVDDH C420 - PP5V7_LCM_AVDDH C4203 - PP5V7_LCM_AVDDH C4204 - PP5V7_LCM_AVDDH 8- Check: PP1V8_LCM_CONN = ( 1.8 Volts ) FL4205 - PP1V8_LCM_CONN C4205 - PP1V8_LCM_CONN C4206 - PP1V8_LCM_CONN 9- Check : CONTINUITY - J4200 PINS FROM INCOMING SUPPLY ON FILTER / SHORTS FL4220 - LCM_TO_CHESTNUT_PWR_EN_CONN C4220 - LCM_TO_CHESTNUT_PWR_EN_CONN FL4221 - AP_TO_LCM_RESET_L R4220 - AP_TO_LCM_RESET_L C4221 - AP_TO_LCM_RESET_L R4222 - PMU_TO_LCM_PANICB C4222 - PMU_TO_LCM_PANICB 10- Check: - I2C BUS LINE / LOW-SPEED C4223 - I2C2_AP_SDA C4224 - I2C2_AP_SCL 11- Check: MIPI DATA LINES / HIGH-SPEED TO CPU - (THESE SHOULD ALL BE THE SAME) DIODE MODE (IE 433mv) ALSO OPEN CIRCUIT L4200 - MIPI_AP_TO_LCM_CLK_CONN_P / N L4201 - MIPI_AP_TO_LCM_DATA0_CONN_P / N L4202 - MIPI_AP_TO_LCM_DATA1_CONN_P / N if all above is ok then: 12- Re-ball or replace ( U4000 ) the Display & Touch Power IC. Regards Dee Sent from my X98 Plus 3G using Tapatalk |
The Following 6 Users Say Thank You to deegee2016 For This Useful Post: |
03-24-2018, 01:07 | #13 (permalink) |
Member: 1071201 Status: Offline Thanks Meter: 4 | Awesome guide deegee2016! This will help me a lot. Today i didn't have time at the shop,but this weekend i'll try to solve this one. Thanks a lot buddy |
