Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 03-20-2018, 17:18   #1 (permalink)
Member: 1071201
Thanks Meter: 4
iPhone 6s Backlight PP_GPU Short - Not ic,not filter,not coil
Hi guys,i have this 6s backlight problem. I started testing caps C4020,C4021 they were beeping. Removed U4020 and short was removed.
Then i replaced all backlight kit. All new. U4020 / D4020 / L4021 / D4021 / L4020. New ic,no short on C4020 but still no backlight.
Then i found another short on PP_GPU. All the caps on that line(PP_GPU)are beeping. Anyone have an idea that what could it be?
Thanks in advance.
Old 03-20-2018, 18:59   #2 (permalink)
Member: 2634857
Thanks Meter: 25
PP_GPU is low resistance line abt 35 ohms so will beep its a low power line so 35ohms over 1v or so line is not shorted....
Hope this helps before pulling any more components off the board....
Sent from my X98 Plus 3G using Tapatalk
Old 03-20-2018, 19:01   #3 (permalink)
Member: 2634857
Thanks Meter: 25
Also Diode mode is not really any good on filters you need to use ohms
Old 03-20-2018, 21:03   #4 (permalink)
Member: 1071201
Thanks Meter: 4
Just for the record i'm not pulling out components randonly,just those ones that i quote that are part of the circuit.
Thank's for the information,so if i don't have a GPU short,i'm kind lost. I measured TP1120 and i have 8,2ohms,anyway i don't know waht to do about that info.
Old 03-20-2018, 22:53   #5 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
PP_GPU not shorted.
Working board, TP1120-0.005, TP1100-0.013 (Diode mode)
Can you post value of diode mode TP20/21/22?
Old 03-21-2018, 10:46   #6 (permalink)
Member: 2634857
Thanks Meter: 25
Voltage readings on i6 diode mode on PP_GPU.
First to check PMU IC output 11 way voltages:
PP_CPU 0.775V-1.0V = 148mv
PP_VAR_SOC 0.9V-0.95V = 335mv
*PP_GPU 0.9V-0.95V = 0.92mv / 52.6ohms
PP1V8_SDRAM 1.8V CPU =
PP1V2_SDRAM 1.2V CPU =
PP0V95_FIXED_SOC 0.95V CPU =
PP1V8 1.8V CPU
PP1V2 1.2V
PP1V2_OSCAR 1.2V
PP1V8_OSCAR 1.8V
PP1V8_GRAPE 1.8V
if all working fine, to check CPU 11 way voltages:
PP3V3-USB覧A8 CPU = 528mv
PP1V8_VA_L9_L67覧U0900、U1601
PP3V0_TRISTAR覧U1700 USB
PP3V0_IMU覧U1901
PP3V0_NAND覧U0604
PP3V3_ACC覧U1700 USB
PP3V0_PROX_ALS覧J111
PP1V0覧A8 CPU
PP3V0_PROX_IRLED覧J111
PP1V8_ALWAYS覧A8 CPU
PP3V0_MESA覧U2100
Hope this helps .
The Following 3 Users Say Thank You to deegee2016 For This Useful Post:
Old 03-21-2018, 16:39   #7 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
This is about ip6s, not for ip6.
The Following User Says Thank You to ninos22 For This Useful Post:
Old 03-21-2018, 17:04   #8 (permalink)
Member: 2634857
Thanks Meter: 25
I'm giving him an idea how to go abt things , check your power rails first...same principle whether or not i6 ,6s etc.
The Following User Says Thank You to deegee2016 For This Useful Post:
Old 03-23-2018, 15:04   #9 (permalink)
Member: 1071201
Thanks Meter: 4
Thank you for the help guys. Didn't solve the problem yet but i'll keep trying.
Old 03-23-2018, 17:07   #10 (permalink)
Member: 2634857
Thanks Meter: 25
Hi mate if you can wait a few will provide testing steps for you later. For backlight and image circuit ...
Old 03-23-2018, 18:27   #11 (permalink)
Member: 2634857
Thanks Meter: 25
deegee
www.dgpcrepairs.co.uk
Backlight Test Sequence i6s (820-5507)
STEPS:
1- Test with other LCD and also try original or known good
2- Check the BackLight coils: TEST OPEN CIRCUIT
FL4211 - PP_LCM_BL_ANODE
FL4212 - PP_LCM_BL_CAT1
FL4213 - PP_LCM_BL_CAT2
3- Check the Capacitors:
C4211 - PP_LCM_BL_ANODE_CONN
C4212 - PP_LCM_BL_CAT1
C4213 - PP_LCM_BL_CAT2
4- Continuity Test: J4200 (TEST FROM INOMING SIDE TO J4200 PIN)
5- Check the Components: The voltage on these component must be VCC_MAIN voltage (3.7 ~ 4.1) V .
C4020 - PP_VCC_MAIN
C4021 - PP_VCC_MAIN
L4020 - PP_VCC_MAIN
L4021 - PP_VCC_MAIN
6- Check the Capacitors: SHORT CIRCUIT/LEAK
C4022 - PP_LCM_BL_ANODE
C4023 - PP_LCM_BL_ANODE
7- Check the Diode: OL / >20V
D4020
D4021
8- Check the Components: I2C BUS DATA - IF RESISTORS ARE DAMAGED THE BUS WONT FUNCTION AS IT WILL BE HELD LOW, NEEDS TO BE HIGH
R4020 - DWI_PMGR_TO_BACKLIGHT_SCLK
C4026 - I2C0_AP_SDA
C4024 - I2C0_AP_SCL
C4025 - I2C0_AP_SCL_MUON
R4021 - I2C0_AP_SCL
If all above is ok then:
9- Re-ball or replace ( U4020 ) the BackLight IC.
Regards Dee
The Following 2 Users Say Thank You to deegee2016 For This Useful Post:
Old 03-23-2018, 18:28   #12 (permalink)
Member: 2634857
Thanks Meter: 25
deegee COPYRIGHT 2016
No Image Test Sequence i6s (820-5507)
STEPS:
2- Check the LCD connector (J4200) Resistances on pins
MAIN SUPPLY (IF DEVICE BOOTS THEN THIS IS OK)
3- Check: - MAIN SUPPLY ( VCC_MAIN = 3.6 ~ 4.2 Volts )
C4000 - VCC_MAIN
L4000 - VCC_MAIN
4- Check: PP6V0_LCM_BOOST = (6.0 volts)
C4007 - PP6V0_LCM_BOOST
C4008 - PP6V0_LCM_BOOST
5- Check: PN5V7_LCM_MESON_AVDDN = (5.7V /- volts)
C4001 - PN5V7_LCM_MESON_AVDDN
C4006 - PN5V7_LCM_MESON_AVDDN
FL4207 - PN5V7_LCM_MESON_AVDDN
C4207 - PN5V7_LCM_MESON_AVDDN
6- Check: PP5V7_MESON_AVDDH = ( 5.7 Volts /+ )
C4005 - PP5V7_MESON_AVDDH
FL4208 - PP5V7_MESON_AVDDH
C4208 - PP5V7_MESON_AVDDH
7- Check: PP5V7_LCM_AVDDH = ( 5.7 Volts /+ )
C4004 - PP5V7_LCM_AVDDH
FL4200 - PP5V7_LCM_AVDDH
C4200 - PP5V7_LCM_AVDDH
C4201 - PP5V7_LCM_AVDDH
C420 - PP5V7_LCM_AVDDH
C4203 - PP5V7_LCM_AVDDH
C4204 - PP5V7_LCM_AVDDH
8- Check: PP1V8_LCM_CONN = ( 1.8 Volts )
FL4205 - PP1V8_LCM_CONN
C4205 - PP1V8_LCM_CONN
C4206 - PP1V8_LCM_CONN
9- Check : CONTINUITY - J4200 PINS FROM INCOMING SUPPLY ON FILTER / SHORTS
FL4220 - LCM_TO_CHESTNUT_PWR_EN_CONN
C4220 - LCM_TO_CHESTNUT_PWR_EN_CONN
FL4221 - AP_TO_LCM_RESET_L
R4220 - AP_TO_LCM_RESET_L
C4221 - AP_TO_LCM_RESET_L
R4222 - PMU_TO_LCM_PANICB
C4222 - PMU_TO_LCM_PANICB
10- Check: - I2C BUS LINE / LOW-SPEED
C4223 - I2C2_AP_SDA
C4224 - I2C2_AP_SCL
11- Check: MIPI DATA LINES / HIGH-SPEED TO CPU - (THESE SHOULD ALL BE THE SAME) DIODE MODE (IE 433mv) ALSO OPEN CIRCUIT
L4200 - MIPI_AP_TO_LCM_CLK_CONN_P / N
L4201 - MIPI_AP_TO_LCM_DATA0_CONN_P / N
L4202 - MIPI_AP_TO_LCM_DATA1_CONN_P / N
if all above is ok then:
12- Re-ball or replace ( U4000 ) the Display & Touch Power IC.
Regards Dee
The Following 6 Users Say Thank You to deegee2016 For This Useful Post:
Old 03-24-2018, 01:07   #13 (permalink)
Member: 1071201
Thanks Meter: 4
Awesome guide deegee2016! This will help me a lot. Today i didn't have time at the shop,but this weekend i'll try to solve this one. Thanks a lot buddy
Page generated in 0.28489 seconds with 8 queries
