07-23-2017, 10:14 | #1 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1926381 Status: Offline Thanks Meter: 1 | iPhone 6S charging problem voltage drop |
The Following User Says Thank You to sussexman For This Useful Post: |
01-29-2018, 03:59 | #8 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Monrovia
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | Problem on ''Main Logic Board'' charging voltage are not stable they are fluctuating in between 1v to 3v Replaced 3, U2 Reballed Audio IC Replaced Tigris U2300 Replaced charging Flex But issue is not solving...... |
05-01-2018, 16:35 | #13 (permalink) |
Junior Member Join Date: Apr 2017
Member: 2711298 Status: Offline Thanks Meter: 1 | there is not l2300 in iphone 6s if you meant u2300 or Q2300. BEFORE REPLACING YOU NEED TO CHECK IF THEY ARE GONE OFF OR NOT. CHECK THE FOLLOWING COMPONENTS VOLTAGES C4503=5.1V IF GOOD THAN CHECK TRISTAR C4502=1.8V & C4502 3.0V REMEMBER YOU WILL SEE THE VOLTAGE DROPS BECAUSE OF THE PROBLEM SOMEWHERE. BUT MAKE SURE YOU GET THE VOLTAGE BEFORE DROPING. IF IT GIVES THE REQUIRE VOLTAGE AND DROPS IT MEAN TRISTAR IS GOOD. FAULT IS ELSEWHERE. BUT IF IT WONT GIVE VOLTAGE AT ALL THAN CHANGE TRISTAR U4500 IF TRISTAR IS GOOD CHECK PMIC VOLTAGE C1240=1.1V 220 RESISTANCE C1271=0.8V 240R TP1100=0.6V 015 TP1120= 007R C2132=1.8V 200R C1200=0.9V 050R C2114=1.2V 290R C1150= 0.7V 110R IF VOLTAGE ARE GOOD BUT DROPING THAN TELL ME. BUT IF VOLTAGE NOT GOOD AT ALL THAN PMIC IS NOT GOOD |
The Following User Says Thank You to aqeeltahir17 For This Useful Post: |
10-19-2019, 22:30 | #14 (permalink) | |
Junior Member Join Date: Aug 2007
Member: 568552 Status: Offline Thanks Meter: 1 | Quote:
Anyone had luck with this? I have checked all these voltages and everything is fine, voltages are there but they are dropping and come back. The only difference is that on TP1100 I have 0.9V and on C1150 I have good voltage but resistance is 050 in diode mode. I have changed the capacitor but it is the same. iPhone is pulling around 0.4A when plugged to a charger and then drops to 0, then again comes to 0.4A and loops. What else to check? BTW, I can't find C1271 on iPhone 6S. | |
