12-13-2016, 21:48 | #1 (permalink) |
Crazy Poster Join Date: Oct 2016 Location: nederland
Member: 2636928 Status: Offline Thanks Meter: 6 | iphone 6s light sensor problem i Have here about 15 front camera flex cables from multiple suppliers, but strange enough with non of them the light sensor is working. This is real, I tested a lot. The ones with the pink mirror (light sensor) don't work, only the ones with a yellow mirror (like the original) I did contact multiple suppliers but nobody knows or is interested in it, I searched the internet but found nothing. There is always a chance of breaking the proximity sensor while removing the flex cable out of the bracket. Why i can't find anything about it? Why nobody noticed this, am I wrong? Does anyone have front camera flex cables with a working light sensor? |
02-06-2017, 15:01 | #3 (permalink) |
Member: 2636928 Status: Offline Thanks Meter: 6 | really, am i the only one? Did somebody replace the iPhone 6S front camera flex cable and check the auto brightness function? For months i am searching for a working flex cable, i spent hours on it with more than 30 flex cables form more than 10 suppliers, tested on different phones, but it's not working, when putting the auto brightness slider on it moves a bit before the center and stays there. Please can somebody confirm/check this? It's driving me crazy. (at this time there are also flexcables with yellow light sensors, but also not working in my opinion) |
02-06-2017, 15:10 | #4 (permalink) |
No Life Poster Join Date: Jun 2003 Location: KA , Deutschland Age: 47
Member: 32168 Status: Offline Thanks Meter: 183 | I guess you did something wrong or the phone has another problem.....i have changed lots of flexes without problems....first take one phone verified.....also display....and try to check the parts... regards |
02-06-2017, 15:24 | #6 (permalink) |
Member: 2636928 Status: Offline Thanks Meter: 6 | Hi jan, really thanks for your reply When I read your message, i replaced the test flex cable with an original (with broken prox sensor) and it worked perfect. Do you check the auto brightness function when a flex cable is installed? |
02-06-2017, 16:59 | #7 (permalink) | |
Member: 32168 Status: Offline Thanks Meter: 183 | Quote:
yes but proximity sensor is only for turn off display during the calls...the auto brightness i check all the time after i change display...usually problems appears with proximity sensor because of bad quality of glass from display.....try to make the glass a little bit darker... regards | |
02-06-2017, 17:01 | #8 (permalink) | |
and also dont forget to put the clock time right in order for auto brightness to work properly....to not be the phone set on night shift regards | |
02-06-2017, 17:54 | #9 (permalink) |
Member: 2636928 Status: Offline Thanks Meter: 6 | Ok, thanks, but the proximity is not the problem, and night shift is off, I can change to the original front camera flex and auto brightness is working, change it to one of my another flex cables and it is not sliding anymore and back to original it's working and also on different original screens. I will keep ordering them by different suppliers, but there is already a lot of difference between my ordered cables. Thanks jan, if there is somebody else, please share your experience |
08-05-2017, 03:45 | #10 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2662292 Status: Offline Thanks Meter: 0 | I can confirm the issue. Wanted to replace the front flex due to the front camera being affected from broken screen. - I have 5 flex cables from different vendors here. Everything works on them except for the light sensor - When plugging in back the original flex (the one with the bad front camera) the light sensor works again. Did you ever find a solution to this issue? |
