Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 12-09-2016, 22:50   #1 (permalink)
Member: 1191636
Thanks Meter: 4
Arrow Iphone 6s nand error 4014
Hi
I have iphone 6s error 4014
I replace the nand flash from iPhone icluod
It's work OK but not active
In restore with iTunes
Not. I don't have programmer nand
Old 12-10-2016, 10:29   #2 (permalink)
Member: 1191636
Thanks Meter: 4
Any body here ???????????????? ...
Old 12-11-2016, 11:12   #3 (permalink)
Member: 1191636
Thanks Meter: 4
Hi please
Any solution I have 2 iphone same error 4014
Old 12-11-2016, 13:45   #4 (permalink)
Member: 2320407
Thanks Meter: 73
Hello yes I am here tell me what is your problem
Old 12-11-2016, 20:11   #5 (permalink)
Member: 1191636
Thanks Meter: 4
Thanks
I have iphone 6s error 4014 I replace nand flash .I take the nand flash from iPhone icluod
Then restore with iTunes ok
But at finally error message not active this iphone.
Old 12-11-2016, 20:21   #6 (permalink)
Member: 2320407
Thanks Meter: 73
this is because of SN incompatible with new IMEI ! so you need to reprogram the NEW NAND or try reball old NAND
because of APPLE security you can only change components you are forbidden to replace the following
NAND,CPU,BB-CPU,eEEprom,fingerprint, WIFI !
I am a Signal-level technician !
regards
Old 12-11-2016, 21:59   #7 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 90
regards
Exactly +++++++++++++
Old 12-11-2016, 22:57   #8 (permalink)
Member: 1191636
Thanks Meter: 4
Thank you very very much
Then
What models programmer to use for reprogramming nand flash iphone 6s.
Thanks again
Old 01-12-2017, 10:11   #9 (permalink)
Member: 1333287
Thanks Meter: 11
hi i iphone 6 erorr 4014 how to fix pliss photos fix
Old 01-12-2017, 11:57   #10 (permalink)
Member: 1939450
Thanks Meter: 122
Then
Thanks again
You can also order a pre programmed nand from aliexpress. Some seller do this service. You give them your serial number and they will put it for you in the nand. This way you only have to replace it an dont need to by expensive NAND programmer.
The Following User Says Thank You to timvandenboo For This Useful Post:
Old 02-07-2017, 00:44   #11 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 393
I had an iphone 6s with 4014. C1515 was shorted next to the nand. I removed the shorted caps and the phone came out of DFU mode and back alive. Hope my experience will help some of you.
The Following 2 Users Say Thank You to HDccam For This Useful Post:
Old 02-07-2017, 00:51   #12 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 393
Old 05-30-2017, 10:40   #13 (permalink)
Member: 2703838
I also changed NAND and copy data by using WL PCIE NAND tool. But when I put my iPhone into DFU mode, just after few apple logo showed up it turned off. Then iTunes says error 4014. Is that a same problem everybody talked above? Maybe when I remove NAND I gave a damage to right side of nand. There's very small parts. I removed C1515 but no change. You guys' help would be greatly appreciated.
Old 09-23-2017, 22:03   #14 (permalink)
Member: 1546723
ibb . co / mXSqKQ (deleted spaces)
SOLUTION
check the capacitors of the nand, sure one of them not work properly, change and check not contiuinity
Old 10-18-2017, 10:15   #15 (permalink)
gsmanam's Avatar
Member: 2581716
Sonork: 30294069
Thanks Meter: 86
iphone 6s 413 error Need Help
iphone 6s 413 Error Need Help
Page generated in 0.42523 seconds with 7 queries
