Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 03-19-2019, 17:29   #1 (permalink)
Member: 2568440
Thanks Meter: 3
Iphone 6s no service after tristar change
Hi friends!! How are you!? �� To day i change the tristar on 6s whit battery drain problem. Remove the old tristar cleaning bga on the board and solder new tristar. The phone power on! No hot and no battery drain! Except I don’have signal anymore. The message says: Upgrade the phone! The wifi work, the bluetooth work, the front camera back camera and flash work, vibradash work, audio speaker work! Everything works except the network. If I type *#06# imei does not appear. In the general settings, about appear imei. Not appear modem firmware. Can you give me a hand? What could be the problem? Thank you friends!
Old 03-19-2019, 18:38   #2 (permalink)
Member: 685256
Thanks Meter: 4
Rebbal the baseband and be ok
The Following User Says Thank You to krasnall For This Useful Post:
Old 03-19-2019, 18:42   #3 (permalink)
Member: 2568440
Thanks Meter: 3
Thanks bro!
Do you say that the heat caused problems with the baseband?
Old 03-19-2019, 18:53   #4 (permalink)
GSM Deals's Avatar
Member: 3936
Thanks Meter: 225
Originally Posted by brek89 View Post
Thanks bro!
yes obviously try to adjust your hot air gun to lower temp
regards
Old 03-20-2019, 08:30   #5 (permalink)
Member: 1554684
Thanks Meter: 6
Thanks bro!
yes. i had same problem. re flowing baseband solved the problem .
Old 03-20-2019, 09:29   #6 (permalink)
bobo bokota's Avatar
Member: 2148606
Thanks Meter: 161
Reball Ic wtr
Envoyé de mon iPhone en utilisant Tapatalk
Old 03-20-2019, 15:46   #7 (permalink)
Member: 2568440
Thanks Meter: 3
Thank you friends for your interest! Unfortunately I discovered a further problem. The iPhone is not recognized by the computer. Yellow triangle. Do you say that the problem is always the baseband? Thank you.
Old 03-20-2019, 16:52   #8 (permalink)
Member: 2568440
Thanks Meter: 3
I have no more problems than battery drain. But now the cellular network doesn't work I don't have imei ne firmware modem. The battery recharges well and the duration is normal. But if I connect to the PC it is not recognized and an error appears. As if there was a problem with data transfer. If it was something in short I think it would overheat and the battery would give the same problem. I had problems with the Q4500 mosfet but I replaced it and I got it from an iphone 6 it looks like the same component.
Page generated in 0.25595 seconds with 7 queries
