Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 10-14-2017, 15:50   #1 (permalink)
Member: 2045117
Thanks Meter: 6
iPhone 6S No touch ID
After repairing an non backlight issue (FL4211) this iPhne 6S is working OK. Only TOUCH ID isn't working... I checked all fuses around J4200, they are all OK. (FL4100; FL4110; FL4112; FL4107; FL4105; FL4120; FL4134; FL4131l FL4130)
Also there appears no message about the TOUCH ID when I start the phone, only if I want to add a fingerprint it results directly in a failure. Can it possibly be U4040 ? (I'am not sure, because I have the possibility to add a fingerprint, but this will result directly into a failure).
Hope someone can help
Old 10-14-2017, 17:16   #2 (permalink)
Member: 2045117
Thanks Meter: 6
SOLVED:
Seems that some copy screens are not working with iOS 11 . I attached an origional LCD and restored the phone in DFU mode, now the touch ID is working. But if I switch over to the copy screen the TOUC ID isn't working anymore and only working on the origional LCD again after a full restore.
I now used a Tianma LCD, assembly and the touch ID is fine
Old 10-14-2017, 17:56   #3 (permalink)
Member: 1388158
Thanks Meter: 22
i would be looking for a problem in the flex cable what is under the lcd sheet cover, may be wrongly plugged in, bad backlight with forse touch
Old 10-18-2017, 21:44   #4 (permalink)
Member: 2768893
Thanks Meter: 2
Good point of view
Old 04-13-2018, 13:33   #5 (permalink)
Member: 2356771
Thank you very much for your experiment I have just done that and it works.
Replaced the Lcd screen for a customer touch id stopped working the next day.
replaced another screen never worked restored the phone did not work.
replaced the lcd screen with original never worked.
Finally with the original Lcd screen restored the phone and it worked.
Page generated in 0.20057 seconds with 7 queries
