01-16-2017, 04:47 | #1 (permalink) |
No Life Poster Join Date: Jul 2016
Member: 2598526 Status: Offline Thanks Meter: 52 | iPhone 6s PMIC keeps shorting Remove PMIC, short gone. Only there when installed. Any ideas? |
01-16-2017, 04:54 | #2 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Earth
Member: 813803 Status: Offline Thanks Meter: 120 | Are you sure there is no short after you remove PMIC? Are you testing for short with DCPS or multimeter? You need to look on ZXW or Pads and see all the different lines/netnames that connect to PMIC and test for short with multimeter! |
01-16-2017, 04:56 | #3 (permalink) | |
Member: 2598526 Status: Offline Thanks Meter: 52 | Quote:
I'm sure I'm testing with a multimeter in diode mode and beep mode. When PMIC in place there's a short on vcc_main and only pmic gets hot. Remove pmic and no short on vcc_main | |
01-16-2017, 05:04 | #4 (permalink) |
Member: 813803 Status: Offline Thanks Meter: 120 | ok thats good, when you clean solder of pads under pmic make sure that there isn't exposed lines, thats why I never use solderwick to clean solder I remove solder with the soldering iron and flux and leave small solder on pads, not flat! After that I put a little flux on pads so they help stick, then I align PMIC and push down (NOT TOO HARD!) and it is stuck. Then I look under microscope with board on angle so i can see if PMIC is aligned properly, then apple heat. That is perfect way in my opinion. |
01-16-2017, 05:09 | #5 (permalink) | |
Thanks. I never use solderwick to clean pads. You think it could be a solder issue? | |
01-16-2017, 05:15 | #6 (permalink) |
Member: 813803 Status: Offline Thanks Meter: 120 | Maybe, like in this picture you can see a track is a little exposed so sometimes solder can connect 2 pads after you put PMIC on. Hard for me to know where the short is without the phone infront of me. |
01-16-2017, 18:52 | #9 (permalink) |
Member: 2598526 Status: Offline Thanks Meter: 52 | iPhone 6s PMIC keeps shorting What's the best tip to use for cleaning pads? I've been using this one Last edited by short_toground; 01-16-2017 at 19:26. |
The Following User Says Thank You to short_toground For This Useful Post: |
01-16-2017, 20:55 | #10 (permalink) |
Freak Poster Join Date: Sep 2015
Member: 2453408 Status: Offline Thanks Meter: 63 | 2nd visible from left but that looks like cheap chinese soldering iron so you are probably going to lift some pads with it be careful, dont slide over just press to the board |
The Following User Says Thank You to Kradziej For This Useful Post: |
01-16-2017, 21:08 | #11 (permalink) |
Member: 2598526 Status: Offline Thanks Meter: 52 | So I'm testing the vcc_main points on the PCB with pmic removed and I measure multiple shorts to ground but if I measure vcc_main from another spot like a capacitor it doesn't read shorted. Only at the pmic pins |
01-17-2017, 04:23 | #14 (permalink) | |
Member: 2453408 Status: Offline Thanks Meter: 63 | Quote:
this one you have is not that flat though, its rounded, close enough but better look for similar one but with flat surface | |
01-17-2017, 05:29 | #15 (permalink) | |
Member: 813803 Status: Offline Thanks Meter: 120 | Quote:
I agree that tip is the best for picking up solder, but I disagree with using wick to pick up solder under big chips. When Apple ship out their boards to production before components are installed, they have little solder on pads, not flat. Using wick can expose copper and hidden tracks! Sent from my iPhone using Tapatalk Pro | |
