Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 12-05-2016, 11:23   #1 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
iPhone 6s PP_CPU / PP_GPU short
TP_1120, TP_1100 both test points shorted to ground.
Phone is starting but restarts every 2 min.
I think problem is common i have seen this short on 3x 6s.
Any possible shorted capacitors?
- no water damage -
The Following User Says Thank You to ninos22 For This Useful Post:
Old 12-05-2016, 22:29   #2 (permalink)
Member: 2320407
Thanks Meter: 88
CPU PROBLEM because of too much heating
Old 12-06-2016, 17:44   #3 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
any ways to confirm?
Old 12-06-2016, 19:52   #4 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
Shorted or low resistance 30ohm-70ohm ???
Old 12-06-2016, 22:26   #5 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
Shorted to gnd (beep)
Old 12-06-2016, 23:05   #6 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
"Beep" doesn't mean short circuit because many multimeters starts the "beep" at 40-70ohms. Short circuit means 0-5 ohms
The Following User Says Thank You to Platijet For This Useful Post:
Old 12-07-2016, 13:13   #7 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
🇬🇷Thanks for your answer. I measure resistant and is:
TP-1120= ~8 ohms
TP-1100= ~13 ohms
Old 04-28-2017, 07:53   #8 (permalink)
Member: 2515187
Thanks Meter: 114
Hello
I have same problem.
Did you find any solution?
Old 04-28-2017, 22:12   #9 (permalink)
mobileunlockers's Avatar
Member: 396778
Thanks Meter: 155
Remove the one of the caps and give direct current between 2v to 4v and see whats heats up. Use freez spray or thermal camera.
Old 04-29-2017, 07:07   #10 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
Did you ever use thermal camera or you suppose that it will work?
Old 04-29-2017, 09:18   #11 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
Originally Posted by Pallle View Post
Hello
FIRST measure the exact resistance and post here.
Old 06-09-2017, 19:12   #12 (permalink)
Member: 2629127
Smile I find solution now and iphone work correctly now
when disconnect lcd and battery connector compeletly
And connect lcd connector and then battery connector
Connect lightning cable
Then apple logo some tomes shown in lcd for few secounds and gone backlight
Yes no backlight!!!
I find solution
GPU SOLDERS PROBLEM!!!
Push strongly left side of CPU with finger to connect pins under the gpu to board
Yes backlight come back and device worked correctly until you push cpu to the board
So must use the brackets that pushe cpu to the board
It is silmpest way to solve this problem
Don't use heating cpu to repair GPU solders pins
May short circuit other pins under cpu
Old 06-11-2017, 23:10   #13 (permalink)
Member: 2625076
Thanks Meter: 4
tp1120 144 ohms and beep
tp1100 540 ohms and beep
Old 06-11-2017, 23:39   #14 (permalink)
Member: 2106911
Thanks Meter: 67
TP1100 16 ohms
TP1120 10 ohms in board with cloud but ok and it beeps so ....
Old 06-16-2017, 05:32   #15 (permalink)
Member: 2691507
Thanks Meter: 100
- no water damage -
The capacitors on the 3rd pic, the symbol is different, I think they are different, they also beep on two of the the iPad Air 2 I'm working on.
in my situation the iPad will stay in DFU mode and with not switch to restore so it stays in "waiting for ipad" in iTunes.
The iPad had a short cap and didn't turn on, then I found the short and replaced the cap, now it will be detected when plug-n to usb by iTunes, but no restore
Hope that helps.
Page generated in 0.25978 seconds with 9 queries
