08-22-2019, 17:09 | #1 (permalink) |
Junior Member Join Date: Jun 2010 Age: 34
Member: 1332167 Status: Offline Thanks Meter: 4 | iphone 6s shor q2300 * By removing that short circuit it disappears. How to solve the problem? |
The Following 2 Users Say Thank You to javadx2 For This Useful Post: |
08-22-2019, 19:24 | #3 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Congo Kinshasa
Member: 2148606 Status: Offline Sonork: Bobobokota Thanks Meter: 496 | Remove caps C3618 RF IPhone 6splus full short solve https://r.tapatalk.com/shareLink?sha...4&share_type=t Envoyé de mon iPhone en utilisant Tapatalk |
The Following User Says Thank You to bobo bokota For This Useful Post: |
08-22-2019, 19:24 | #4 (permalink) |
08-22-2019, 21:05 | #5 (permalink) | |
Freak Poster Join Date: Feb 2014
Member: 2127758 Status: Offline Thanks Meter: 26 | Quote:
I don't understand you... If you point the tester on A/B pin of Q2300 and to ground you will find a short? If A/B of Q2300 is shorted to ground, you have a short on PP_VCC_MAIN.... Usually solved removing and replacing C5283 / C5284 RF | |
The Following 2 Users Say Thank You to Sakalalina For This Useful Post: |
08-23-2019, 14:11 | #6 (permalink) | |
Member: 1332167 Status: Offline Thanks Meter: 4 | Quote:
I remove c5283 and c5283 ,my problem not solve. Plz hellp | |
The Following User Says Thank You to javadx2 For This Useful Post: |
08-26-2019, 20:58 | #10 (permalink) |
Member: 2127758 Status: Offline Thanks Meter: 26 | Pins A and B of Q2300 are connected to PP_VCC_MAIN, so you have to search a short on that line... You got two ways: 1) Using Phoneboard or a schematic, you can find and remove all caps in PP_VCC_MAIN untill you will find the problem....hoping that the problem is a cap.... 2) You can inject 1v on battery connector or in PP_VCC_MAIN line with a current of 0.6/0.8A and check what's the component that become hot ( @Raainxx )...if it's a capacitor, then u can remove it or replace it... |
