iphone 6s wifi ic lost pin 37 2 Attachment(s) after remove iphone 6s wifi ic because make short circuit i lost an pin on board. pin is the 37 net whit x606 (PADS reference). as i see whit microscope the pad is broken but i not see the x606 :confused compared another board but not removed components and resin...look's there not the x606 :confused: so i will know if the broken pad is necessary. any help appreciated,thanks. |
changed ic whitout the pin connexion,added the previous detached caps now phone go on but setup menu very slow to open and wifi greyed + bt never find. |
Pin 37 can not be restored, it's just a jtag. After installing a new chip, did you connect it to the NAND via the WL programmer? |
no programmer :( not just to change the chip? old one was shorted so need be change. |
ok thnks a lot,now i understand why in an video i see they remove nand chip and write something in. also in other videos thecnicians spend lot of time to scratch and try to find shorted part in wifi chip... |
wifi ic 2 pins shorted,after remove chip the phone is ok,whit new wifi chip the phone is laggy when open setup menu', not find any wifi,no address wifi. |
urgent question for my collegues friends,what happen if i take the wifi ic from another 6s working main board? need also reprogrammed? |
each iphone 6s onward phone has programmed wifi ic and you cannot replace with other iphone 6s IC..it should be its own ..the programmer copy the wifi ic mac address and other data to the new chip before installing |
ok,be clear,need an programmer. idea's for a simple and cheap solution? |
actually i have in my hands naviplus 3000s pro,i can be do? |
thanks |
i have exactly same problem pad 37, sorry for outdated post refresh , but did anyone sort the problem ? wifi unbind by irepair box , still grey and bt spin , mac address n/a , the only difference might be the chip number apparently 338s00043 is compatible instead of 339s00033? |
