Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 01-12-2018, 18:59   #1 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 69
iphone 6s wifi ic lost pin 37
after remove iphone 6s wifi ic because make short circuit i lost an pin on board.
pin is the 37 net whit x606 (PADS reference).
as i see whit microscope the pad is broken but i not see the x606 :confused
compared another board but not removed components and resin...look's there not the x606
so i will know if the broken pad is necessary.
any help appreciated,thanks.
Old 01-15-2018, 13:03   #2 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 69
changed ic whitout the pin connexion,added the previous detached caps now phone go on but setup menu very slow to open and wifi greyed + bt never find.
Old 01-16-2018, 09:35   #3 (permalink)
Member: 2681265
Thanks Meter: 16
Pin 37 can not be restored, it's just a jtag. After installing a new chip, did you connect it to the NAND via the WL programmer?
Old 01-16-2018, 09:51   #4 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 69
no programmer
not just to change the chip?
old one was shorted so need be change.
Old 01-16-2018, 10:30   #5 (permalink)
Member: 2681265
Thanks Meter: 16
Originally Posted by nykocam View Post
no programmer
Starting from 6S and above you need a programmer when replacing nand or wi-fi DropMeFiles ? free one-click file sharing service
The Following User Says Thank You to PRO-mobile For This Useful Post:
Old 01-16-2018, 10:51   #6 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 69
ok thnks a lot,now i understand why in an video i see they remove nand chip and write something in.
also in other videos thecnicians spend lot of time to scratch and try to find shorted part in wifi chip...
Old 01-17-2018, 03:04   #7 (permalink)
Member: 2018487
Thanks Meter: 2
But not shorted anymore? and which line was sorted?
Old 01-22-2018, 19:31   #8 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 69
wifi ic 2 pins shorted,after remove chip the phone is ok,whit new wifi chip the phone is laggy when open setup menu', not find any wifi,no address wifi.
Old 01-31-2018, 18:22   #9 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 69
urgent question for my collegues friends,what happen if i take the wifi ic from another 6s working main board?
need also reprogrammed?
Old 01-31-2018, 19:05   #10 (permalink)
Crazy Poster
Member: 1803209
Thanks Meter: 10
each iphone 6s onward phone has programmed wifi ic and you cannot replace with other iphone 6s IC..it should be its own ..the programmer copy the wifi ic mac address and other data to the new chip before installing
Old 01-31-2018, 20:38   #11 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 69
ok,be clear,need an programmer.
idea's for a simple and cheap solution?
Old 03-13-2018, 19:33   #12 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 69
actually i have in my hands naviplus 3000s pro,i can be do?
Old 03-13-2018, 20:40   #13 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 122
Sorry you can't. 6s and above use PCI-Express NAND.
Old 03-16-2018, 13:32   #14 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 69
suggest another interface plz,better one can be used in future too.
thanks
Page generated in 0.53282 seconds with 8 queries
