Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 11-15-2016, 09:03   #1 (permalink)
Jermainegenius's Avatar
Member: 1300324
Sonork: 📱 876-439-8006
Thanks Meter: 112
iPhone 7 apple logo reboots every 3 seconds
iPhone 7 apple logo reboots every 3 seconds after simcard along with gevey been removed after been stuck into sim reader.
A technician remove the tray along with the gevey and sim when the phone was on which it shouldnt had been that that way, the phone should be off
I guess thats what causes the problem, he check the sim reader if its damage but the sim reader is ok, he disconnected the battery for 10 minutes then reconnect and its the same apple logo stuck and rebooting issue after 3 seconds.
I restored the phone through itunes it restored successfully and its the same problem, Any suggesstions????
Old 11-16-2016, 07:19   #2 (permalink)
Super Moderator
mihut's Avatar
Member: 824
Sonork: 100.1666666
Thanks Meter: 13,668
hi dear
when you restored the iphone did it activate also?and if you please send me the screenshot of about display then i can suggest you
__________________
Just Follow the Rules and Be Polite
Saying "thank you" can be hard. But it's so important.
Old 11-16-2016, 11:31   #3 (permalink)
Member: 1300324
Thanks Meter: 112
Originally Posted by mihut View Post
hi dear
When i restored the iphone, it restored successful but do not startup to activation screen, it only reboot to apple logo then reboot again and again and again
Old 11-16-2016, 12:47   #4 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 3,859
Keep plug in charger and see whether working or not
Old 11-17-2016, 02:02   #5 (permalink)
Member: 1300324
Thanks Meter: 112
I have done that already the same day, it also take the recovery mode command and the itunes cable stay still without restarting. When it comes from that mode it starts to loop and restart again
Old 11-17-2016, 02:13   #6 (permalink)
Member: 1203369
Thanks Meter: 13
put in dfu mode and restore with itunes
Old 11-17-2016, 04:22   #7 (permalink)
Member: 1300324
Thanks Meter: 112
I already done that.. Its the same thing
Old 11-18-2016, 06:44   #8 (permalink)
Member: 2137773
Thanks Meter: 9
You can ReiBoot. It is a very powerful tool that forces reboot your iPhone without losing data.
The Following User Says Thank You to monim01 For This Useful Post:
Old 11-20-2016, 11:01   #9 (permalink)
Member: 731127
Thanks Meter: 11
one question i want to ask that you said that the technician unpluged the battery for 10 mins. did he unplugged the battery in front of you or not. if yes than try to change the battery if no then he might have changed your battery. in both cases you just try to replace the battery. that might helpful to you. reply if you find it useful.
Old 11-20-2016, 11:53   #10 (permalink)
chubbie's Avatar
Member: 281801
Sonork: 100.1608672
Thanks Meter: 151
~Check battery connector
~Try and change battery
~CHECK FOR CIRCUIT SHORT
~Service & Rehot PCB
Old 12-06-2016, 09:34   #11 (permalink)
Member: 2655669
Thanks Meter: 6
You really should take your iPhone 7 to Apple Store or other authorized service center. It must be a hardware problem.
Old 12-06-2016, 13:30   #12 (permalink)
DIN231080's Avatar
Member: 523792
Thanks Meter: 95
100% hardware may be inner sim slot sort ground any pin
Old 12-17-2016, 20:54   #13 (permalink)
Member: 2662116
Thanks Meter: 3
This is Main Board Issue.
Yeah this is little problem iPhone 7 randomly restarting
It's Sounds like a hardware problem with your main iphone7 board. This is the most common cause of unexpected restarts.
You must get a genius bar appointment at your nearest apple store and tell them your issue. They will most probably replace your phone.
If you don't have a local Apple store number, contact AppleCare (800) 275-2273 and describe the issue to them.
It's within the realm of possibility that it's software related, but it's rare for software issues to cause this. If you want to rule that out, perform a restore and set it up as new, then monitor for continued problems.
Old 03-09-2017, 07:33   #14 (permalink)
Member: 2692542
Thanks Meter: 24
%100 hardware problem
may be power ic...
Old 03-17-2017, 09:26   #15 (permalink)
Member: 2694911
change power ic this be done , today i done one this problem via changing power ic
Page generated in 0.36021 seconds with 7 queries
