Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 10-27-2017, 15:07   #1 (permalink)
Member: 1714728
Thanks Meter: 11
iPhone 6 became dead while changing lcd
iPhone 6 became dead while changing lcd on power supply it showing till 0.80 and becoming 0 display blank
Old 10-27-2017, 18:36   #2 (permalink)
Member: 1714728
Thanks Meter: 11
No it. Is showing only 0.09 and becoming 0
Old 10-27-2017, 21:09   #3 (permalink)
Member: 2235761
Thanks Meter: 3
mmmm seems like long screw damaged!
Old 10-28-2017, 01:04   #4 (permalink)
Member: 1714728
Thanks Meter: 11
No it is not that problem
Old 10-28-2017, 01:11   #5 (permalink)
Member: 1714728
Thanks Meter: 11
Changed display Ic now set is ok lcd ok but no light it showing temperature high if I remove light Ic running normal I have replaced new Ic also but no luck same no light and showing temperature high please help
Old 10-28-2017, 08:16   #6 (permalink)
fasttechjlm's Avatar
Member: 268415
Thanks Meter: 57
check PP_LCM_BL_ANODE if short to ground then replace c1530,c1531, c1505, also replace D1501.
Old 10-28-2017, 13:47   #7 (permalink)
Techgsmnet's Avatar
Member: 499855
Thanks Meter: 397
check FL2024, 2025 and 2026 before doing other !!!
Old 11-03-2017, 22:12   #8 (permalink)
Member: 1714728
Thanks Meter: 11
still waiting not find any solution
Old 11-03-2017, 22:13   #9 (permalink)
Member: 1714728
Thanks Meter: 11
this line is ok it is not connected to ground
Old 11-03-2017, 22:58   #10 (permalink)
Member: 619511
Thanks Meter: 53
i have the same problem after replace lcd no display and when i cconnect to itune always in recovery mode. any help
Old 11-06-2017, 00:21   #11 (permalink)
Member: 1714728
Thanks Meter: 11
Problem solved now it is working 👌🏻
The Following User Says Thank You to shivashaker For This Useful Post:
Old 11-06-2017, 17:01   #12 (permalink)
Member: 619511
Thanks Meter: 53
how did u solve the problem pl explain
Old 01-13-2018, 19:48   #13 (permalink)
Member: 658949
Thanks Meter: 13
Please explain how did you solved it. Thanks
Page generated in 0.18704 seconds with 8 queries
