11-27-2018, 19:25 | #1 (permalink) |
Freak Poster Join Date: Jan 2009 Location: kosovo
Member: 952091 Status: Offline Thanks Meter: 11 | iPhone 7 charging Anyone can help?? Can someone suggest me what to do. Last edited by gjizaqin; 11-27-2018 at 19:35. |
The Following User Says Thank You to gjizaqin For This Useful Post: |
11-28-2018, 02:48 | #3 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | white pin are NC so no problem. when u replace new tristar, better clean ic from original ball, and reball it yourself before. original ball need higher temperature, and ic can't take his place by himself. so sometime will cause problem. |
The Following User Says Thank You to BouRRi_GSM For This Useful Post: |
11-29-2018, 20:56 | #5 (permalink) |
Freak Poster Join Date: Mar 2013 Location: Greece Age: 35
Member: 1903358 Status: Offline Thanks Meter: 146 | Quote: The battery drain can be anything. |
12-04-2018, 15:01 | #9 (permalink) | |
Freak Poster Join Date: Nov 2017 Location: Canada
Member: 2777379 Status: Offline Thanks Meter: 34 | Quote:
Connect your logic board to a power supply, boot the phone... Check how much amperage it's drawing after the boot sequence is finished once your phone is on the lock screen. When powered off the only lines that draws current are PP_VCC_MAIN and PP_VCC_BATT, if your phone charges correctly while turned off then you know these lines are ok, you have over a hundred different lines that has current going through when turned on, any of these could be shorted and drawing too much current from the battery to attempt charging it. | |
