05-15-2018, 02:34 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: Canada
Member: 1211915 Status: Offline Sonork: 345634564 Thanks Meter: 93 | IPHONE 7 ICLOUD remove HARDWARE METHOD, Any expert??? Which ICS are needed to replace for icloud removal on Iphone7 1 CPU, 2 NAND, 3 BB What else? which ICs are required other than above? ANyone removed successfully? Please update results. thank you |
05-15-2018, 09:09 | #2 (permalink) | |
Freak Poster Join Date: Dec 2014 Location: PCB
Member: 2320407 Status: Offline Thanks Meter: 88 | Quote:
The real thing is about iPhones icloud locked devices is very simple like this first of All we MUST have 2 boards (one icloud " clean board state" + non working board water damaged,dropped, broken into 2 parts !) the idea is to move chips from the broken PCB to the iCloud locked one (we are ONLY making use of the PCB itself ) to get a good device so there is nothing called removing iCloud ! but we say this or do this for sake of reputaion & advertisment.... I do this personally only if I have 100% trusted board ! for the chips that needed to be moved inorder to get a working device they are 1-CPU for sure 2-NAND 3 (CPU & NAND EEPROM) 4-Baseband (Intel or Qualcomm) 5-Baseband & CPU EEPROM 6-WIFI (if you do not have a programmer) 7-Fingerprint I do it for data recovery ! Goodluck everyone ! | |
The Following 2 Users Say Thank You to ctccellulaire For This Useful Post: |
05-15-2018, 17:17 | #3 (permalink) | |
Member: 1211915 Status: Offline Sonork: 345634564 Thanks Meter: 93 | Quote:
Thank you for replying, Can you tell about number 5 EEPROM, I googled and found that there are two eeprom which needs to be replaced, But in schematic there is only one EEPROM, please can you mark second EEPROM needs to be replaced. I have one working board perfect condition like new with icloud and i have other DONOR board without icloud(dead board) Thank you | |
