07-30-2017, 04:36 | #1 (permalink) |
Insane Poster Join Date: Dec 2009
Member: 1191636 Status: Offline Thanks Meter: 6 | iPhone 7 plus error 9 i have iPhone 7 plus get error with iTunes i change ic changing but the same error 9 i change cable data but the same error 9 thanks |
The Following User Says Thank You to mustafa12 For This Useful Post: |
08-02-2017, 02:17 | #7 (permalink) |
Junior Member Join Date: Jun 2017
Member: 2729413 Status: Offline Thanks Meter: 15 | check the lines from the EEPROM to the CPU (SDA and SCL) and see if they read around .42 in diode mode. |
The Following User Says Thank You to johnbaker26 For This Useful Post: |
08-03-2017, 03:49 | #8 (permalink) |
Freak Poster Join Date: Jul 2017
Member: 2737783 Status: Offline Thanks Meter: 39 | I saw this tutorial on 3uTools web, you may have a look: How to Fix Error 9, 4005, 4013 or 4014 in iTunes/3uTools? |
The Following 2 Users Say Thank You to TGB For This Useful Post: |
07-18-2019, 10:13 | #13 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Denmark Age: 41
Member: 268415 Status: Offline Thanks Meter: 57 | check PP3V0_NAND 1st. if short to ground, find short and remove it. most of the time its pp3v0_nand. if thats ok check all other nand power rails like, PP0V9_NAND, pp1v8, if they are also fine which most of the time they do. only then you should go for nand reball procedure. |
03-10-2020, 12:27 | #15 (permalink) |
No Life Poster Join Date: May 2012 Location: In Your Heart Age: 37
Member: 1759636 Status: Offline Sonork: 100.1591515 Thanks Meter: 785 | Remove nand connect with with IPBOX make backup from nand and erase all nand then write backup again and reboll nand ic and put it to phone and flash it this is the procedure which will work 100% thnks br WBGSM |
The Following 2 Users Say Thank You to WBGSM For This Useful Post: |
