11-15-2017, 02:42 | #1 (permalink) |
Freak Poster Join Date: Feb 2015 Location: new zealand
Member: 2350837 Status: Offline Thanks Meter: 8 | Iphone 7 stuck on apple logo |
11-15-2017, 05:24 | #2 (permalink) |
Freak Poster Join Date: Nov 2003 Location: Malaysia Age: 41
Member: 44095 Status: Offline Thanks Meter: 38 | maybe is Audio ic problem https://www.youtube.com/watch?v=Bro_fIP2_mY&t=5s if you can restore finish no error try this solution i tried 2 pcs 7 and 7plus it working |
The Following User Says Thank You to plentong For This Useful Post: |
11-15-2017, 16:55 | #3 (permalink) | |
Major Poster Join Date: Dec 2007
Member: 657332 Status: Offline Thanks Meter: 16 | Quote:
connect all connectors, home button and front camera flex, unless it will not boot up Sent from my iPhone using Tapatalk | |
The Following User Says Thank You to dvdbackuper For This Useful Post: |
11-26-2017, 17:36 | #5 (permalink) | |
No Life Poster Join Date: May 2006 Age: 44
Member: 278546 Status: Offline Thanks Meter: 145 | Quote:
01-26-2018, 16:17 | #9 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2665825 Status: Offline Thanks Meter: 1 | There is a way though so make sure you follow these instructions carefully: 1. Hold the home and power buttons down together 2. The Apple logo should disappear from your screen 3. After a couple of minutes it should reappear – when it does, release the buttons 4. Quickly hold them both down again until your device goes off 5. Plug the USB cable into your computer (not to your device yet) 6. Hold the Home button down and plug the cable to your device 7. When you see the Connect to iTunes screen, release the button 8. iTunes will open and the Device in Recovery message will appear Click on Restore If the method can't fix your problem, you may try this method. Fix Issue Like iPhone Stuck on Apple Logo |
10-19-2020, 02:22 | #10 (permalink) |
Junior Member Join Date: Aug 2020 Location: USA Age: 25
Member: 2965059 Status: Offline Thanks Meter: 1 | Maybe iOS system has some problems. You can try these methods. 1. Force Restart iPhone Press and hold the Power button and Home button together until you see the Apple logo appear on the screen. 2. Put Your iPhone into Recovery Mode 3. Put Your iPhone into DFU Mode You can try force restart the iPhone first. Press and hold the Power button and Home button together until you see the Apple logo appear on the screen. Put Your iPhone into Recovery Mode. If that does not work, put it into DFU Mode. Still does not work. Use iOS System fix software like TunesKit iOS System Recovery, which can fix iOS system problems without data loss. |
02-03-2021, 06:58 | #11 (permalink) |
Crazy Poster Join Date: Jul 2020 Location: China Age: 25
Member: 2964041 Status: Offline Thanks Meter: 3 | Hey, there, to fix iPhone stuck on Apple Logo, you could try the following ways. 1. Force restart iPhone; 2. Apply Joyoshare UltFix, TunesKit, etc professional iPhone repair tools; (no data loss) 3. Restore iPhone via iTunes. (Data Loss) |
02-03-2021, 19:33 | #12 (permalink) | ||
Freak Poster Join Date: Mar 2013 Location: Greece Age: 35
Member: 1903358 Status: Offline Thanks Meter: 146 | Quote:
