iPhone 7 Touch screen, weird problem! Hi. I have iPhone 7 with weird touch screen problem. After screen replacement, touch screen is not working. But when I disconnect home button flex, it works normally. Have tried with other button and other original lcd, and even made a factory reset. Didn't helped :( Connector is looking good and in diode mode on multimeter all pins on connector J4502 and J3801 have correct values. Checked FL3904 and its ok. I have noticed that when home button is connected, there is no PP1V8_TOUCH. One more thing. When home button is disconnected, iPhone does not enable assistive touch so I cannot activate iPhone and therefore can't be used. Does anyone knows what could be wrong? Please help. Thanks |
hello try another flex cable for the home buuton |
i have same problem with iPhone 7 touch not working, i tried two screens but same problem, i checked J4502 and found that all pins have correct values except pin 18 have 250 resistance which should be around 490 this line for ( SPI_AP_TO_TOUCH_MOSI_CONN ) coming directly from the CPU to FL3904 which replaced but still same value and touch still not working, please need you guidance to fix this problem .Thanks |
Connect lcd flex and home button, and check with diode mode PP1V8_TOUCH |
i connected LCD and home, switched phone on and keep measured both side of FL3910 while phone booting the PP1V8_TOUCH is missing .what is that meaning .the resistance value of pin 9 while phone off with no battery is 530 with connected LCD and home . I'm confusing what is going on phone was working fine but no speaker i opend it and cliked dock flex and speaker works but touch stopped working . i discunnctd the dock flex and changed LCD and tried with other phone housing but no luck. Please help. |
please need your help and guidance to solve this problem . |
did you found the solution? I have the saaaame problem. With j3801 connected touch not work. |
So no solution for this problem? |
i need a help, i have a same problem please help |
3d touch ic problem for me |
u3801 u3801 u3801 u3801 u3801 u3801 7 plus |
