Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 06-13-2017, 22:27   #1 (permalink)
Member: 193584
Thanks Meter: 7
iPhone 7 Touch screen, weird problem!
Hi. I have iPhone 7 with weird touch screen problem. After screen replacement, touch screen is not working. But when I disconnect home button flex, it works normally. Have tried with other button and other original lcd, and even made a factory reset. Didn't helped
Connector is looking good and in diode mode on multimeter all pins on connector J4502 and J3801 have correct values. Checked FL3904 and its ok. I have noticed that when home button is connected, there is no PP1V8_TOUCH.
One more thing. When home button is disconnected, iPhone does not enable assistive touch so I cannot activate iPhone and therefore can't be used.
Does anyone knows what could be wrong? Please help. Thanks
Old 06-13-2017, 23:14   #2 (permalink)
Member: 2106911
Thanks Meter: 65
hello try another flex cable for the home buuton
The Following User Says Thank You to vinse For This Useful Post:
Old 06-14-2017, 17:02   #3 (permalink)
Member: 193584
Thanks Meter: 7
have tried, didn't helped.
Old 03-13-2018, 09:54   #4 (permalink)
Member: 2625122
Thanks Meter: 22
i have same problem with iPhone 7 touch not working, i tried two screens but same problem, i checked J4502 and found that all pins have correct values except pin 18 have 250 resistance which should be around 490 this line for ( SPI_AP_TO_TOUCH_MOSI_CONN ) coming directly from the CPU to FL3904 which replaced but still same value and touch still not working, please need you guidance to fix this problem .Thanks
Old 03-13-2018, 20:42   #5 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 140
Connect lcd flex and home button, and check with diode mode PP1V8_TOUCH
Old 03-14-2018, 18:41   #6 (permalink)
Member: 2625122
Thanks Meter: 22
i connected LCD and home, switched phone on and keep measured both side of FL3910 while phone booting the PP1V8_TOUCH is missing .what is that meaning .the resistance value of pin 9 while phone off with no battery is 530 with connected LCD and home .
I'm confusing what is going on phone was working fine but no speaker i opend it and cliked dock flex and speaker works but touch stopped working . i discunnctd the dock flex and changed LCD and tried with other phone housing but no luck.
Please help.
Old 03-20-2018, 00:12   #7 (permalink)
Member: 2625122
Thanks Meter: 22
please need your help and guidance to solve this problem .
Old 08-02-2018, 16:47   #8 (permalink)
Member: 1005873
did you found the solution? I have the saaaame problem. With j3801 connected touch not work.
Old 08-22-2018, 22:21   #9 (permalink)
Member: 193584
Thanks Meter: 7
So no solution for this problem?
Old 11-30-2019, 20:16   #10 (permalink)
Member: 158930
Thanks Meter: 4
i need a help, i have a same problem please help
Old 12-06-2019, 09:50   #11 (permalink)
Member: 2533922
Thanks Meter: 7
3d touch ic problem for me
Old 12-06-2019, 10:00   #12 (permalink)
Member: 2533922
Thanks Meter: 7
u3801
u3801
u3801
u3801
u3801
u3801 7 plus
Page generated in 0.32603 seconds with 7 queries
