Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 12-14-2017, 12:45   #1 (permalink)
Member: 2643514
Thanks Meter: 28
iPhone 7 USB not detecting after U2 Replacment
Hi I have had an iphone 7 that was stuck on connect to itunes after u2 ic being damaged when customer tried to charge his open on a bus and power surge killed his phone. After replacing the U2 IC phone has started to work fine now but when connected to the charger it does not charge and does not draw in any current. Does the iphone 7 has Q2 sort of ic for USB like iphone 5,5s? may be they need bypassing. I have replaced the U2 ic twice now and still no luck with charging. Any help will be appreciated
Old 12-15-2017, 01:20   #2 (permalink)
Member: 2330242
Thanks Meter: 3
Use original one from anathema board
Old 12-15-2017, 05:36   #3 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
Try rehot or replace same ic first.
This happen sometime when ic is bad or some point not connected.
Old 12-15-2017, 12:44   #4 (permalink)
Member: 2643514
Thanks Meter: 28
i have tired and it still does not work, im sure it has seperate ics like Q2 for usb connectror
Old 12-15-2017, 15:10   #5 (permalink)
Member: 2515187
Thanks Meter: 114
Hello
Remove Q4001 and make jumper PIN2 to PIN3.
The Following User Says Thank You to Pallle For This Useful Post:
Old 12-15-2017, 16:00   #6 (permalink)
Member: 2643514
Thanks Meter: 28
thanks pallle mate i have done the jumper and it still does not work
Old 12-17-2017, 02:42   #7 (permalink)
Member: 2110834
Thanks Meter: 9
It will be faulty ic.
Sent from my ONEPLUS A3003 using Tapatalk
Old 12-17-2017, 07:55   #8 (permalink)
abukuru's Avatar
Member: 2495283
Sonork: gsmvilla.com
Thanks Meter: 12
Reball u2 ic and clean pcb pin with lead Cleaner’s...and put back....this happens when some Pin’s not connected very well
Sent from my iPhone using Tapatalk Pro
Old 03-01-2018, 04:19   #9 (permalink)
Member: 2018487
Thanks Meter: 2
has anyone fixed this issue yet? can u pls share? thanks in advance
Old 03-01-2018, 06:58   #10 (permalink)
Member: 530705
Sonork: 1616834
Thanks Meter: 833
reball audio ic and make sure apply jumper see image
Old 07-04-2018, 12:15   #11 (permalink)
Member: 2126761
Thanks Meter: 4
did you fix it my friend?
Page generated in 0.71144 seconds with 9 queries
