09-14-2017, 02:28 | #1 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1426467 Status: Offline Thanks Meter: 3 | Iphone 7plus only charging with computer not charging with charger Sent from my iPhone using Tapatalk |
The Following User Says Thank You to select77715 For This Useful Post: |
03-22-2019, 14:32 | #7 (permalink) |
Freak Poster Join Date: May 2013 Location: Netherlands
Member: 1939450 Status: Offline Thanks Meter: 165 | Same here, got an iphone 7 here. Changed mosfet, tigiris and tristar in correct order. But not working. also changed dock, battery and small ic q4001. Only charges on pc... not wall. |
03-22-2019, 17:47 | #8 (permalink) |
Freak Poster Join Date: Mar 2013 Location: Greece Age: 35
Member: 1903358 Status: Offline Thanks Meter: 146 | Plug the wall charger and check: 90_TRISTAR_DP1_CONN_P (normal 2.50v) 90_TRISTAR_DP1_CONN_N (normal 2.50v) If your value is 3.30v phone will not charge, and you must check C4004 (0.01UF). Replace with same part. |
The Following User Says Thank You to ninos22 For This Useful Post: |
03-24-2019, 17:44 | #11 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2092009 Status: Offline Thanks Meter: 30 | i have same issue with iphone 7 its charging with computer but not charging with charger....i also replace tristar trigris all the releted charging parts i replaced...problum is still same |
03-24-2019, 17:45 | #12 (permalink) |
Member: 2092009 Status: Offline Thanks Meter: 30 | PP_BATT_VCC voltage is ok with pc and wall charger 3.75V ok also connecting with pc....i check all voltage TIGRIS_BATTERY_SWI_CONN --- 1.65Vok C2101--- 5V ok C4004--- 1.8V ok C4006----5V ok C4003--- 3V ok also replace Q4001 AND Q2101 need help...this is bad case Report Post |
03-25-2019, 11:54 | #14 (permalink) |
Member: 1939450 Status: Offline Thanks Meter: 165 | C4004 did indead need to be changed. Changed it then not chargin at all. Also turned out there was a sh*itty chinese copy battery in. Putted an good know working one in and. Wooooh charging normally. |
