Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 06-09-2018, 12:32   #1 (permalink)
Member: 1520821
Sonork: 100.1641523
Thanks Meter: 40
Smile Iphone 8 backlight solution 100%
IPHONE 8 BACKLIGHT SOLUTION 100%...
https://www.4shared.com/photo/ibzzopLSee/pjimage.html
The Following 3 Users Say Thank You to murali shiju For This Useful Post:
Old 09-08-2018, 08:34   #2 (permalink)
Member: 1911098
Thanks Meter: 16
Hi
Just want to share something I came across. Had an iPhone 8 with backlight not working at all. Not just some parts being dark. So I checked all three fuses which you are pointing in your picture and all three was fine. Then I had another look and noticed that a IC close by was damaged. It was pressed and had a corner missing. So I replaced it and backlight was working again
https://imgur.com/a/xAyVHv2
The Following User Says Thank You to simeon_tsvetkov For This Useful Post:
Old 08-07-2019, 01:51   #3 (permalink)
Member: 1995710
Originally Posted by simeon_tsvetkov View Post
Hi
thank you so much i replaced this but did not do a good job and got mad then tried again and worked. the filters were fine just like you! thanks!
Old 02-18-2020, 17:03   #4 (permalink)
Member: 49046
Thanks Meter: 25
thanks. it worked after ic replacement.
Old 03-16-2020, 11:39   #5 (permalink)
Member: 2726740
iphone 8 no touch at all
iPhone 8 came in simple screen replacement turn out to be no touch
screen did work for 5 mints then it stopped i was having a trouble with home button while i was looking into it that's where screen stopped i tried new Pfc connector all the caps around the Pfc connector can't get touch back
Old 03-26-2020, 03:33   #6 (permalink)
Member: 2865098
Thanks Meter: 2
If your iPhone backlight is not working, it can be caused by either software glitches or hardware issue. You need first to troubleshooting it. If it's a software problem, just use a professional iOS system recovery tool to fix it without data loss; otherwise, it is advisable to head for the Apple Store to resolve the hardware issue rather than replace it by yourself since fixing the iPhone backlight is extremely sophisticated.
Page generated in 0.12621 seconds with 8 queries
