Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-30-2018, 13:01   #1 (permalink)
porn's Avatar
Member: 134206
Thanks Meter: 15
iphone 8 plus home button problem
Hi
have a iphone 8 plus with home button problem - can use finger print id but does not recognise the press - have changed the lcd but cannot see any damage to the button
Old 08-16-2018, 18:22   #2 (permalink)
Member: 2511554
Sonork: 100.1671270
Thanks Meter: 8
I saw similar problem in this forum, i believe the issue was taptic engine and for other guy it was button itself. So need diagnostics to check if that button work on other device, if not then button is damaged.
Old 08-23-2018, 11:26   #3 (permalink)
Member: 2494453
Thanks Meter: 189
Re: fix home button
You could use AssitiveTouch, it is convenient.
Old 09-08-2018, 16:58   #4 (permalink)
Member: 2228162
Sonork: 23243564rtrwe
Thanks Meter: 25
taptic engine change and done confirm
Old 10-17-2018, 12:03   #5 (permalink)
Member: 2861866
Thanks Meter: 40
Hey! whether you clean your finger? if your finger have water or oil, the home button will have some problem in recognise the press.
Old 01-11-2019, 19:10   #6 (permalink)
Member: 2660544
I have a device with the same problem, I made the exchange of the taptic engine and it did not solve. Apparently the button is not damaged, does any have any solutions?
Old 01-13-2019, 22:14   #7 (permalink)
Member: 2807920
Thanks Meter: 2
guys stop telling this poster nonsense, he obviously knows that dirty fingers won't get recognized (I have more luck, even finger covered in dirt will register push, not touch id tho). lets figure it out, get another home button, any 8 plus home button will do, just install new one, check if it works, then check taptic engine, and connections to mother board,after that let us know more.
Page generated in 0.23569 seconds with 7 queries
