11-28-2018, 01:09 | #1 (permalink) |
Freak Poster Join Date: Sep 2011 Location: Mexico City
Member: 1664131 Status: Offline Sonork: 100.1636755 Thanks Meter: 38 | iphone 8 plus voltage not get in battery ways Voltage in charging shows 5.10V but in battery conector there not voltage. I remove capacitor C3292 and not success... voltage not get in battery connector. I try change battery, charge flex and restore but pc donīt recognize. Please help!! |
The Following User Says Thank You to rorcorporation For This Useful Post: |
11-28-2018, 15:33 | #2 (permalink) |
Freak Poster Join Date: Nov 2017 Location: Canada
Member: 2777379 Status: Offline Thanks Meter: 34 | Hello, I'm not sure what you're describing, have you tried powering the phone from a power supply? You need to if you're going to troubleshoot this. Connect your power supply Write down the current your power supply will draw before you boot the phone and after you press the power button. |
The Following User Says Thank You to 7Axis For This Useful Post: |
11-29-2018, 13:16 | #4 (permalink) | |
Freak Poster Join Date: Mar 2013 Location: Greece Age: 35
Member: 1903358 Status: Offline Thanks Meter: 146 | Quote:
According to schematics you can easily check TP0527 or TP0521 for confirm if dock flex it OK or not. If dock flex its OK go to the next steps, testing HYDRA and TIGRIS charger. 1. Check PP_VAR_USB_RVP for 5v (C6311) to check power supply of HYDRA 2. Check PP_VBUS1_E75 for 5v (C3301) to check power supply of TIGRIS After this steps you have to check outputs of those chips, also MOSFET Q3350. | |
The Following 5 Users Say Thank You to ninos22 For This Useful Post: |
11-30-2018, 02:06 | #5 (permalink) |
Member: 1664131 Status: Offline Sonork: 100.1636755 Thanks Meter: 38 | I have tested with dust remover and the component damaged is Q3350, this component is the first in get warm when I connect the power supply cable. C3353, C3350, C3351 and C3352 not present voltage. |
11-30-2018, 14:40 | #6 (permalink) | |
You need to remove it, so you can drop 5v to the shorted line and you will easily find the shorted component. After your job done you have just to jump it. No need to put it back. | |
12-04-2018, 18:30 | #7 (permalink) | |
Insane Poster Join Date: Apr 2013 Location: London
Member: 1911098 Status: Offline Thanks Meter: 16 | Quote:
What am I looking for ? A component that is getting hot, right ? | |
The Following User Says Thank You to simeon_tsvetkov For This Useful Post: |
05-28-2019, 21:12 | #8 (permalink) | |
Major Poster Join Date: Nov 2004 Age: 46
Member: 93937 Status: Offline Thanks Meter: 3 | Quote:
11-04-2019, 11:33 | #9 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: Romania,Buc
Member: 694535 Status: Offline Thanks Meter: 70 | Quote:
tp0527- 5.09v c6311 - 4.39V c3301 - 5.09V what is the solution ? | |
