03-05-2010, 17:07 | #16 (permalink) |
No Life Poster Join Date: May 2005 Age: 43
Member: 149032 Status: Offline Thanks Meter: 3,808 | Remove the following 8 screws: Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear panel. Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera. One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker. |
The Following 9 Users Say Thank You to gopalhot For This Useful Post: |
03-05-2010, 17:08 | #17 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | Step 14 Use a spudger to gently pry the camera up and out of its housing in the rear panel. The camera cannot be removed entirely yet because it's connected to the bottom of the logic board. |
03-05-2010, 17:09 | #18 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | Step 15 Use a spudger to gently pry up the end of the logic board closest to the dock connector. If the board won't lift up, double check to make sure all the screws securing the logic board have been removed. |
The Following 8 Users Say Thank You to gopalhot For This Useful Post: |
03-05-2010, 17:32 | #21 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | step 6 missing Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables. Use a spudger to disconnect the black ribbon cable labeled "2." |
The Following 14 Users Say Thank You to gopalhot For This Useful Post: |
04-07-2010, 04:50 | #23 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1278609 Status: Offline Thanks Meter: 1 | iphone 3g can't restore hi my iphone don't restore every time i try i get the 1603 or 1604 error... i have tried everything even close itunes and reopen in the middle of the processes...and i always have to hard reset the iphone because it wont stop cycling the restore process... It means my logic board was fried? Any help will be really appreciated. Sorry for my English |
The Following User Says Thank You to pralima87 For This Useful Post: |
05-08-2010, 00:45 | #25 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1224858 Status: Offline Thanks Meter: 6 | Looking for someone with a 3G iphone logic board and a multi-meter Hi Guys, I'm looking for a bit of help from anyone that has a logicboard/motherboard from an iPhone 3G to hand, and a multi-meter… I had to re-attach one of the pins of the SIM card carriage/junctor, due to it shearing off when the SIM card tray was inserted the wrong way round - not by me! So I re-soldered the damaged SIM carriage on to the little of the contact that was left on the Logicboard (point A on attached photo) which all went well… But whilst checking the board with a multimeter I have noticed that there is continuity between the pin I re-soldered and point B on the photo, or any of the other pieces of metal shielding (I presume this is ground?). I don't want to put the phone back together and power it up only to realise something is shorting out and in-turn **** a lot of components… So I would be really grateful if someone could confirm if there should be continuity (connection) between the 2 labeled points (A and B) ? Cheers Oliver |
The Following 6 Users Say Thank You to mr_oj For This Useful Post: |
05-19-2010, 07:36 | #27 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 45
Member: 166746 Status: Offline Thanks Meter: 86 | hi mate, ive got a 3GS here, and there is NO continuity, at those points. cheers Last edited by .::iRizwan::.; 05-27-2010 at 22:02. Reason: Don't need to quote whole post |
05-19-2010, 08:24 | #28 (permalink) |
Freak Poster Join Date: Jul 2006 Location: india
Member: 306087 Status: Offline Thanks Meter: 24 | hi gopal brother can u help for my iphone 2g my phone is disable beca. of wrong password i tryed to restore with itune but not connecting can u please help me i hva dought in hardware but no idea on that so will u please help . thanks in adv. |
The Following User Says Thank You to pawansingh For This Useful Post: |
05-24-2010, 22:54 | #29 (permalink) |
Junior Member Join Date: Jul 2005 Location: US
Member: 161968 Status: Offline Thanks Meter: 3 | Someone have ideea, an 3g with sound problems. I can't hear in earpiece, speaker and the mic is not working. When i try to attach headphones it don't recognize them. Please help |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
