iPhone Hardware problems in one thread http://i50.tinypic.com/mhr1co.jpg SOLUTION: RESTORE TO LATEST FIRMWARE.... and ok iPhone 3G Camera Replacement and Installation Download link (Personal account): http://kewlshare.com/dl/e33385045a22...mBOKI.exe.html http://uploading.com/files/H6PAQZQ1/...mBOKI.exe.html http://s56.radikal.ru/i152/0912/be/4fc14044bc6e.png http://img200.imageshack.us/img200/8...d3b764d59f.png http://img21.imageshack.us/img21/2449/turani.gif plz vote sundorban http://photos-f.ak.fbcdn.net/hphotos..._3263093_n.jpg |
Sorry, the file you requested is either deleted or not found in our database. link is dead please up another link |
no sim problem http://img3.imageshack.us/img3/2203/img0019rv.png http://img171.imageshack.us/img171/3032/img0020m.png REQUIREMENTS: 1.UNA,,LAKAS NG LOOB 2.CROSS SCREW DRIVER 3.CUTTER 4.COATED THIN WIRE 5.SOLDER 6.SCOTCH TAPE OR ADHESIVE ETC.. 7.CHARGING PIN 3310,, OPTIONAL.. 8.PINAKA IMPORTANTE SA LAHAT http://img180.imageshack.us/img180/8990/img0002f.jpg http://img193.imageshack.us/img193/2898/img0006xt.jpg FINISH PRODUCT: http://img41.imageshack.us/img41/7930/img0021e.png http://img185.imageshack.us/img185/6753/sol1.png http://img185.imageshack.us/img185/6753/sol1.png |
iphone 3g backlight iphone 3g backlight http://www.tipo2.com/img/iphone.jpg http://img194.imageshack.us/img194/7339/l2101.jpg |
iphone 2g..dead!help....[Moved] |
how to change iPhone 3G Battery Introduction Each step has a bullet indicating the tool you'll be using. Don't worry about getting lost or confused; hundreds of people have successfully used the Fixit Guide series to repair their laptops. Tools used in this guide -Metal Spudger -Phillips #00 Screwdriver -Spudger Parts relevant to this guide -iPhone 3G Replacement Battery Step 1 — Battery Remove the two Phillips #00 screws from the dock-connector end of the iPhone. http://static2.ifixit.com/igi/6MDaEATCCBdIK3F5.standard |
Step 2 There is a fragile rubber gasket between the silver front bezel and black display assembly. Keep your tool as close to the silver front bezel as possible to prevent damaging the gasket. We recommend a metal spudger for this task, but an X-acto knife should also work, just be careful not to slip. Insert a metal spudger into the seam between the silver front bezel and the black display assembly on the edge closest to the home button. Gently pry the display assembly up from its bezel. http://static1.ifixit.com/igi/ZteoudeGgcNUuQaQ.standard |
Step 3 If necessary, insert the metal spudger in the same manner on the side of the iPhone and continue to pry up gently. Stop using the metal spudger once the display assembly is up enough that you can lift it up with your fingers. Step 4 The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet. Rotate the display assembly up until it is at an angle of approximately 45 degrees. http://static2.ifixit.com/igi/1opQfeBnduhXZ3SF.standard |
Step 5 Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1." http://static1.ifixit.com/igi/pwSlolqxhBFFQOej.standard |
Step 7 Use a spudger to flip up the white plastic tab holding the remaining ribbon cable in place. The white tab will rotate up 90 degrees, releasing the ribbon cable. Slide the black ribbon cable out of its connector, and remove the display assembly from the iPhone. http://static2.ifixit.com/igi/QDOLUTpIiNcdCgKb.standard |
Step 8 Insert your SIM eject tool or a paper clip into the hole next to the headphone jack. Press down on the tool until the SIM card tray pops out. Grasp the SIM card tray and slide it out of the iPhone. http://static2.ifixit.com/igi/EOIPHToqCfIMHyJM.standard |
Step 9 Use a spudger to disconnect the ribbon cable labeled "4." http://static2.ifixit.com/igi/rGWSGdsIfraEEGDF.standard |
Step 10 Use a spudger to disconnect the ribbon cable labeled "5." http://static2.ifixit.com/igi/BQMTNLaEuoTM1dbP.standard |
Step 11 Use a spudger to disconnect the ribbon cable labeled "6." http://static2.ifixit.com/igi/jZ6cQMUHCQjSQYch.standard |
Step 12 Carefully peel up the small sticker labeled "Do not remove." http://static2.ifixit.com/igi/VadTQEnZGGD53CuS.standard |
