Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 03-05-2010, 14:41   #1 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,796
iPhone Hardware problems in one thread
SOLUTION: RESTORE TO LATEST FIRMWARE.... and ok
iPhone 3G Camera Replacement and Installation
Download link (Personal account):
http://kewlshare.com/dl/e33385045a22...mBOKI.exe.html
http://uploading.com/files/H6PAQZQ1/...mBOKI.exe.html
plz vote sundorban
The Following 94 Users Say Thank You to gopalhot For This Useful Post:
Old 03-05-2010, 14:51   #2 (permalink)
Thinh vu's Avatar
Member: 830301
Sonork: heocon
Thanks Meter: 46
Sorry, the file you requested is either deleted or not found in our database.
link is dead please up another link
The Following 3 Users Say Thank You to Thinh vu For This Useful Post:
Old 03-05-2010, 15:13   #3 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,796
no sim problem
REQUIREMENTS:
1.UNA,,LAKAS NG LOOB
2.CROSS SCREW DRIVER
3.CUTTER
4.COATED THIN WIRE
5.SOLDER
6.SCOTCH TAPE OR ADHESIVE ETC..
7.CHARGING PIN 3310,, OPTIONAL..
8.PINAKA IMPORTANTE SA LAHAT
FINISH PRODUCT:
The Following 12 Users Say Thank You to gopalhot For This Useful Post:
Old 03-05-2010, 15:26   #4 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,796
iphone 3g backlight
iphone 3g backlight
The Following 38 Users Say Thank You to gopalhot For This Useful Post:
Old 03-05-2010, 15:39   #5 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,796
iphone 2g..dead!help....[Moved]
The Following 24 Users Say Thank You to gopalhot For This Useful Post:
Old 03-05-2010, 16:38   #6 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,796
how to change iPhone 3G Battery
Introduction
Each step has a bullet indicating the tool you'll be using. Don't worry about getting lost or confused; hundreds of people have successfully used the Fixit Guide series to repair their laptops.
Tools used in this guide
-Metal Spudger
-Phillips #00 Screwdriver
-Spudger
Parts relevant to this guide
-iPhone 3G Replacement Battery
Step 1 Battery
Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
The Following 15 Users Say Thank You to gopalhot For This Useful Post:
Old 03-05-2010, 16:43   #7 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,796
Step 2
There is a fragile rubber gasket between the silver front bezel and black display assembly. Keep your tool as close to the silver front bezel as possible to prevent damaging the gasket.
We recommend a metal spudger for this task, but an X-acto knife should also work, just be careful not to slip.
Insert a metal spudger into the seam between the silver front bezel and the black display assembly on the edge closest to the home button. Gently pry the display assembly up from its bezel.
The Following 13 Users Say Thank You to gopalhot For This Useful Post:
Old 03-05-2010, 16:47   #8 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,796
Step 3
If necessary, insert the metal spudger in the same manner on the side of the iPhone and continue to pry up gently. Stop using the metal spudger once the display assembly is up enough that you can lift it up with your fingers.
Step 4
The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet.
Rotate the display assembly up until it is at an angle of approximately 45 degrees.
Old 03-05-2010, 16:51   #9 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,796
Step 5
Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
The Following 19 Users Say Thank You to gopalhot For This Useful Post:
Old 03-05-2010, 16:58   #10 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,796
Step 7
Use a spudger to flip up the white plastic tab holding the remaining ribbon cable in place. The white tab will rotate up 90 degrees, releasing the ribbon cable.
Slide the black ribbon cable out of its connector, and remove the display assembly from the iPhone.
The Following 10 Users Say Thank You to gopalhot For This Useful Post:
Old 03-05-2010, 17:01   #11 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,796
Step 8
Insert your SIM eject tool or a paper clip into the hole next to the headphone jack.
Press down on the tool until the SIM card tray pops out.
Grasp the SIM card tray and slide it out of the iPhone.
The Following 8 Users Say Thank You to gopalhot For This Useful Post:
Old 03-05-2010, 17:03   #12 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,796
Step 9
Use a spudger to disconnect the ribbon cable labeled "4."
Old 03-05-2010, 17:03   #13 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,796
Step 10
Use a spudger to disconnect the ribbon cable labeled "5."
The Following 9 Users Say Thank You to gopalhot For This Useful Post:
Old 03-05-2010, 17:04   #14 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,796
Step 11
Use a spudger to disconnect the ribbon cable labeled "6."
Old 03-05-2010, 17:06   #15 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,796
Step 12
Carefully peel up the small sticker labeled "Do not remove."
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 12:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 20:20
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 01:44
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 23:36
Page generated in 0.44285 seconds with 9 queries
