Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 03-14-2019, 21:54   #1621 (permalink)
Member: 1740209
Thanks Meter: 35
iPhone 7, charging problem. As soon as the original cable is connected, message is displayed "This Accessory May Not Be Supported". On the screen it is visible that it starts charging but it does not charge after that.
I have tried several other cables, result stays the same.
Help anyone?
Old 06-09-2019, 05:40   #1622 (permalink)
Member: 2907377
Thanks Meter: 3
Help anyone?
It sounds like USB restricted mode is enabled. Look for USB accessories option in your settings, it might be in the security settings, and turn it on. I think that should fix your issue.
If it's still an issue, make sure you try with a genuine apple lightning cable or at the very least a MFI certified cable. 90% of the cables you find these days are all 6 pin fake garbage.
Once you are certain that you have ruled out any possibility of it being the cable itself, try using a different usb port on the computer, if that doesnt work, try using a different computer. If all of those fail, get yourself some IPA (90% or higher) and apply a little bit to a cotton swab or a toothpick and gently clean out the lightning port (this actually should be done first and should be done first and foremost when you suspect a communication/cabling issue).
Old 06-30-2019, 02:48   #1623 (permalink)
Member: 1214267
Sonork: riyasibrahim86
pls need help me..iphone x battery line conection +ve and -ve
Old 06-30-2019, 14:44   #1624 (permalink)
kissssna's Avatar
Member: 810694
Thanks Meter: 30
iPhone X unable to activate after restore
iPhone X
dropped and when tried to restore no error but was unable to activate
getting this error in iTunes
"iphone could not be activated because the activation information could not be obtained from device"
any solution please help
Old 06-30-2019, 17:30   #1625 (permalink)
Member: 2699795
q smart spd flash file need
Old 07-10-2019, 17:11   #1626 (permalink)
Member: 2736155
Thanks Meter: 7
hello everyone
i have an iphone XR which have charging probleme it powers on but not charging even i tryed to turn it off and put the charger it don't power on, i tryed to change connector, battery but same thing .... i think the probleme is with charge ic, if there is schematic for this model please join it here or give me solution to repair it
Old 09-11-2019, 13:09   #1627 (permalink)
Member: 2926350
I have IPhone 5 dead.
I tested the PP_BATT_VCC and PP_VCC_MAIN and they aren't shorted to ground. But while inspecting the board i found the following:
1- line HS3_CONN is shorted to ground.
2- Q8's Drain and Source are shorted.
Can any line of those stop the phone from charging and booting
Old 09-11-2019, 17:38   #1628 (permalink)
Member: 2926350
Problem solved I replaced U21 (Audio Codec IC) and it started operating well now. Thank you
Old 09-17-2019, 07:17   #1629 (permalink)
Member: 341390
Could not search because search is not working.
iPhone 7 mic stopped working after software update and in voice memo says 'no recording device found'. Phone is not in warranty. What can be done to repair this and why apple Care is not repairing it for me since it totally looks like something that they have messed up !
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.26569 seconds with 9 queries
