Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 03-05-2010, 17:07   #16 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
Step 13
Remove the following 8 screws:
Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear panel.
Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera.
One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker.
The Following 9 Users Say Thank You to gopalhot For This Useful Post:
Old 03-05-2010, 17:08   #17 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
Step 14
Use a spudger to gently pry the camera up and out of its housing in the rear panel. The camera cannot be removed entirely yet because it's connected to the bottom of the logic board.
Old 03-05-2010, 17:09   #18 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
Step 15
Use a spudger to gently pry up the end of the logic board closest to the dock connector.
If the board won't lift up, double check to make sure all the screws securing the logic board have been removed.
The Following 8 Users Say Thank You to gopalhot For This Useful Post:
Old 03-05-2010, 17:09   #19 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
Step 16
Slide the logic board towards the dock connector and out of the iPhone.
The Following 10 Users Say Thank You to gopalhot For This Useful Post:
Old 03-05-2010, 17:11   #20 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
Step 17
Use a spudger to pry the battery up from the rear panel. The battery is attached with an adhesive strip around the perimeter of the battery. To prevent the battery from bending during the removal process, we recommend against using just the plastic
vote plz sundorban
The Following 40 Users Say Thank You to gopalhot For This Useful Post:
Old 03-05-2010, 17:32   #21 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
step 6 missing
Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
Use a spudger to disconnect the black ribbon cable labeled "2."
The Following 14 Users Say Thank You to gopalhot For This Useful Post:
Old 03-27-2010, 13:47   #22 (permalink)
zino's Avatar
Member: 18688
Thanks Meter: 69
YouTube - Voir l'intérieur d'un iPhone 3G !
The Following User Says Thank You to zino For This Useful Post:
Old 04-07-2010, 04:50   #23 (permalink)
Member: 1278609
iphone 3g can't restore
hi my iphone don't restore every time i try i get the 1603 or 1604 error...
i have tried everything even close itunes and reopen in the middle of the processes...and i always have to hard reset the iphone because it wont stop cycling the restore process...
It means my logic board was fried?
Any help will be really appreciated.
Sorry for my English
The Following User Says Thank You to pralima87 For This Useful Post:
Old 04-28-2010, 17:04   #24 (permalink)
ask-unlock's Avatar
Member: 1254195
Sonork: 5454
Thanks Meter: 119
Originally Posted by gopalhot View Post
Re: your water damage iPhone 3G, as you said there's no corrosion occur so here's your fix.
Tap a small insulated wire between those point.
If work thiss solution bro when not power up from water damage? thanks so much
The Following 5 Users Say Thank You to ask-unlock For This Useful Post:
Old 05-08-2010, 00:45   #25 (permalink)
Member: 1224858
Thanks Meter: 6
Looking for someone with a 3G iphone logic board and a multi-meter
Hi Guys,
I'm looking for a bit of help from anyone that has a logicboard/motherboard from an iPhone 3G to hand, and a multi-meter…
I had to re-attach one of the pins of the SIM card carriage/junctor, due to it shearing off when the SIM card tray was inserted the wrong way round - not by me!
So I re-soldered the damaged SIM carriage on to the little of the contact that was left on the Logicboard (point A on attached photo) which all went well…
But whilst checking the board with a multimeter I have noticed that there is continuity between the pin I re-soldered and point B on the photo, or any of the other pieces of metal shielding (I presume this is ground?).
I don't want to put the phone back together and power it up only to realise something is shorting out and in-turn **** a lot of components…
So I would be really grateful if someone could confirm if there should be continuity (connection) between the 2 labeled points (A and B) ?
Cheers
Oliver
The Following 6 Users Say Thank You to mr_oj For This Useful Post:
Old 05-13-2010, 12:19   #26 (permalink)
Member: 711270
Thanks Meter: 30
Iphone 3G keep appear headphone~~~Help~~~
Old 05-19-2010, 07:36   #27 (permalink)
silveraxe's Avatar
Member: 166746
Thanks Meter: 86
hi mate,
ive got a 3GS here, and there is NO continuity, at those points.
cheers
Last edited by .::iRizwan::.; 05-27-2010 at 22:02. Reason: Don't need to quote whole post
Old 05-19-2010, 08:24   #28 (permalink)
pawansingh's Avatar
Member: 306087
Thanks Meter: 24
hi gopal brother can u help for my iphone 2g
my phone is disable beca. of wrong password i tryed to restore with itune but not connecting can u please help me i hva dought in hardware but no idea on that so will u please help . thanks in adv.
The Following User Says Thank You to pawansingh For This Useful Post:
Old 05-24-2010, 22:54   #29 (permalink)
Member: 161968
Thanks Meter: 3
Someone have ideea, an 3g with sound problems. I can't hear in earpiece, speaker and the mic is not working. When i try to attach headphones it don't recognize them. Please help
The Following 2 Users Say Thank You to grim_repoo For This Useful Post:
Old 05-29-2010, 09:50   #30 (permalink)
bluejack22002's Avatar
Member: 741453
Thanks Meter: 43
have someone a solution for iphone 3g unknow error 9 when restoring? thanks
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.28460 seconds with 11 queries
