11-21-2013, 04:07 | #1457 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1989066 Status: Offline Thanks Meter: 0 | ipad 2 IC camera I got ipad 2 with rear camera not working, but the camera itself is working fine in other ipad, so I suspect the broken part is the camera IC. is there anyone know which one is the camera ic ? I can't swap the board since one is the 3G ipad and another just wifi ipad. thanks. |
11-24-2013, 15:57 | #1458 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2071976 Status: Offline Thanks Meter: 0 | Hey guys, I am having a problem with a iphone 5. I opened it to take a look at the motherboard, and when i put it back together, it stopped showing correct battery %. THe battery% changes while i charge it, but as soon as i disconnect it from the charger, it will not change until it turns off completely. Anyone knows a solution to this problem? It is really annoying |
12-01-2013, 21:02 | #1459 (permalink) | ||
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Quote:
12-20-2013, 04:17 | #1462 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Jakarta Indonesia
Member: 896483 Status: Offline Thanks Meter: 95 | Dear sir my iphone 4s i cant restore my iphone itunes say error 1 not -1, help me please? before i restore my iphone is always searching br gita |
01-05-2014, 14:54 | #1463 (permalink) |
Freak Poster Join Date: Jul 2013
Member: 1983950 Status: Offline Thanks Meter: 8 | Iphone 4s with crash problems rear camera and network signal sometimes Hi Mr Wites are here to ask you for help!! I no longer know what to do ... my iphone 4s behaves strange, to say the least. Basically when I open the camera chrasha and phone restarts and the same problem also when there is the module for the camera in fact I tried to exclude the camera back thinking that it could be a problem with the camera and instead chrasha the same!! Furthermore, the phone has another annoying problem namely the telephone network that comes and goes! basically the phone goes on "seeking" immediately after engaging the network even with a good signal but as soon as I try to make a phone call only makes one ring and immediately closes the call!! I tried searching the continuity between (J3_RF) and pin 5 of (U3_RF) with a negative result! There is no continuity! and between the two poles of (C46_RF) there is continuity but only a busted around 550. I want to emphasize that the logic board is missing the component (C196). Can this cause the described problems!? I no longer know what to do ... just wondering help!! also the battery charge is very slow, the battery indicator always remains fixed on the same percentage also under stress! and the phone turns on only if connected to the mains, but I think this problem is caused by a bad solder bridge number 4 pin battery connector will try to resolder on (TP5) ... no water damnage e no corroded component!! Below some pictures!! [IMG=http://imagizer.imageshack.us/v2/150x100q90/600/em69.jpg][/IMG] [IMG=http://imagizer.imageshack.us/v2/150x100q90/545/hw62.jpg][/IMG] [IMG=http://imagizer.imageshack.us/v2/150x100q90/132/3ova.jpg][/IMG] |
01-06-2014, 09:42 | #1464 (permalink) |
Junior Member Join Date: Aug 2007
Member: 576926 Status: Offline Thanks Meter: 0 | hi masters, i need help from you guys. my iphone 4s worked fine till yesterday. my friend's 4S touch screen doesnot work properly, but the LCD is fine. then, my friend wanted me to help him to install his screen on my 4s to test it. The touchscreen didnot work either on my 4s, then we had done the second time. we were not lucky, touchscreen didnot work, but the lcd worked. then we got the result. when i installed my own screen back, my 4s didnot startup. it is totally black. no apple logo. when i connected it to my computer, it keeps beeping. ituns cant find it. and the IC below the lcd connector is hot. it is dead. one of the possible problem is, i think, because the touchscreen didnot work, i cant switch off the phone, and i had to pull out the battery before i disconnected the LCD and touchscreen and reconnected them. but not sure about that. please help me. thanks, |
01-16-2014, 17:51 | #1466 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2053694 Status: Offline Sonork: [email protected] Thanks Meter: 0 | hi, the iphone 3gs is not connnecting to itunes. on connecting it gives error 'the iphone update server could not be connected'. i had tried everything but it is not working. my friend had told me that it might be a hardware problem. so please help me |
01-16-2014, 18:02 | #1467 (permalink) |
Freak Poster Join Date: May 2007 Location: San Jose, Costa Rica Age: 47
Member: 504871 Status: Offline Thanks Meter: 165 | I think is a internet connection problem. Also check itunes hosts file. Reinstall itunes latest version. Enviado desde mi iPhone con Tapatalk |
01-23-2014, 19:20 | #1468 (permalink) |
Member: 2052734 Status: Offline Thanks Meter: 0 | hi masters i have ana i phone 4 the problem with it s wifi can not work only when u get close the modem and i heard about al lot of peopole get the same prblem is there any way to fix it |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
