07-14-2014, 15:08 | #4877 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2217955 Status: Offline Thanks Meter: 0 | Hi! First post here, hope I'm doing it right. I know of some approved methods for replacing IC chips but they all seem to require fairly specialized equipment. I have a water-damaged iPhone 4S board with a suspect U19 digitizer chip - I just want to swap it out with one off a spare board. Is there a way of doing this without reballing stencils etc? This is a one-off exercise (hopefully) so I don't want to buy equipment I'm unlikely to use again. I do have a hot-air station, temp controlled soldering iron and microspcope that I've been using successfully to replace discrete components like caps and connectors. I've got as far as removing the U19 from the board and from the donor board, which I've managed to do fairly neatly without tearing pads or anything. Anyone got any bright ideas? |
07-17-2014, 06:28 | #4878 (permalink) |
Junior Member Join Date: May 2014
Member: 2194317 Status: Offline Thanks Meter: 0 | my iphone 4s locked to o2 uk send sms to someone by it self , i disable facetime and imessage , and i try restore the setting as default but the problem stay so what i can do to slove that problem ? by the way my version ios 7.1.1 and i use r-sim 9 pro ! |
07-19-2014, 02:32 | #4881 (permalink) | |
Crazy Poster Join Date: Aug 2010
Member: 1358006 Status: Offline Thanks Meter: 7 | Iphone hardware and software solutions in 24 hrs Quote:
Don't do, you will brake the pads, see this for reballing: youtu . be/_r1xXED65Pk (delete the space between tu & be) it's xxxtu.be K.R Furqan Inviato dal mio iPhone utilizzando Tapatalk | |
07-20-2014, 05:07 | #4883 (permalink) |
No Life Poster Join Date: Apr 2010
Member: 1276771 Status: Offline Thanks Meter: 33 | iphone 5s before was in searching mode i did restore and update and give me error 1 what is the solution for this need urgent help plss tnx no problem if searching mode again but phone should be removed from recovery mode???? |
07-23-2014, 01:34 | #4889 (permalink) | |
Member: 2217955 Status: Offline Thanks Meter: 0 | Quote:
Anyway my work has ground to a halt until I figure out what to do with my rework station - I just replaced the iron heating element then tested for earthing and discovered there is 27VAC at the tip! Took the station apart (Youde 852D+ - yep, yet another Chinese clone) and found that the only thing that's earthed is the case, and the PCB and everything else is isolated from it. I don't know enough about these things to know what to do about it. Guess I'll post a thread somewhere else on the forum and hope someone can help me. A schematic would be handy, I've searched everywhere. | |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
